Thread: Polar FIS+
Results 1 to 8 of 8
  1. Polar FIS+
    Sep 2008
    SE London
    Has anyone done the upgrade to a Polar FIS+ unit to a Full Height MFD?
    I think (but can't find the thread nor remember if it was this forum) this
    involves removal of the drivers' side drop down pocket. And there were
    hints on that too...
    This exposes the OBDII connector?
    RichardSEL
  2. Re: Polar FIS+
    Sep 2008
    SE London
    Well still searching for the Canbus gateway or controller! Have been in contact with Polar who offered their install notes for Scirocco and suggested that it's up above the clutch pedal. Took down the relevent panels but not seen. Others in other forums have given different locations (behind drivers' side drop down pocket, behind Climatic control panel) but these presumably were locations for LHD models (of various Golfs) Have tried following the OBDII socket leads but they seem to just disappear into a grommet in the drivers' footwell
    Anyone know where this unit is on a RHD 2006 B6 Passat?
    If it's in the centre console behind Climatic control panel, how does this get released?
    Thanks to anyone already in the know!
    RichardSEL
    p.s. Will I have to join the Masons to find out?? ;-)
  3. Re: Polar FIS+
    Mar 2009
    Sleaford, Lincs, UK
    Behind climatronic, remove cd facia trim, then heater trim, then 4x Torx screw holding the climatics in, then you will see the gateway!
    07 Passat SEL Sport TDI 170 R
    Deep Pearl Black
  4. Re: Polar FIS+
    Sep 2008
    SE London
    Could only see two T20 holding Climatic's panel in. Hope that the wiring is long enough to allow removal of Climatic panel. Dark now will check in the morning
    Thanks for your quick reply!
    Which Lodge?
    RichardSEL ;-}
  5. Re: Polar FIS+
    Mar 2009
    Sleaford, Lincs, UK
    Which lodge???
    2x T20's at the bottom
    2x T20's on side
    Do you have climatic or climatronic?
    If the standard S, SE climatic then be careful with the directional cable spring thing, nightmare!
    Deep Pearl Black
  6. Re: Polar FIS+
    Sep 2008
    SE London
    Climatronic as it accepts the (Econ)+(Vent) button's diagnostics commands
    Do I have to take out side panels somehow. As I can't See the other two screws? And I'm nervous about pulling too hard to remove. The panel moves but doesn't want to pull out
    Thanks again for your help
    RichardSEL
  7. Re: Polar FIS+
    Sep 2008
    SE London
    Right, have found the four screws you mentioned -- they were so far recessed missed them in the failing light yesterday
    Have removed the Climatronic panel and can see the Gateway. I only have to remove the plug, not the unit itself.
    And replace it with Polar FIS's plug, the loom then plugs goes into Polar's harness. Other end of harness goes into the Polar unit.
    Can I access the Gateway's plug/socket without removing the metal bracket which the Gateway module is behind? Perhaps via the drivers' side upper tunnel panel? If so, how does that become detached? The lower panel just clipped out.
    Still nervous of snapping something
    RichardSEL
  8. Re: Polar FIS+
    Sep 2008
    SE London
    Just to finish off this thread:
    After much installing, many updates to the PolarFIS+ unit did get it working and, with their latest updates sure is a
    useful unit. Here's a pix but at this resolution it's probably too blurred to see the detail of this ver2.3. However amongst
    its features is turbo boost so not needing another gauge, piping, etc. See the PolarFIS website for more details:
    http://www.auto-polar.com/
    Ver2.3 screen.jpgDownside for me is that it doesn't run for greater than 20mins or so without taking out my aftermarket JVC radio's MFSW buttons interface (Connects2). The programers in Madrid did try a revamp of their software but no go. However from other posters it's fine if you have OEM headunit (RCD300 >RNS510) which uses the CANbus properly to control their functions. PolarFIS uses the redundant Telematics' menu (module 75 in VCDS)
    Alternatives that take their info from the OBDii socket and thus more restricted are:
    Ultra Gauge (couldn't see Boost Pressure from their details) -- about US $105 inc. shipping
    DashDaq -- US $549
    DashBoss which uses a wireless interface -- US $170
    and Kauftec's e-MFA which is only good for Diesels
    RichardSEL
  1. Retro fit MFD/FIS and MFL
    By reynard55 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-11-2010, 05:08 PM
  2. DIS/FIS washer liquid sensor question + some coding questions
    By boooo4 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-03-2010, 11:32 AM
  3. DIS (FIS) configuration and issues
    By wmccann in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-04-2009, 12:32 AM
  4. FIS Display problem
    By johngibson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 01-08-2007, 12:13 PM
  5. FIS ??? + Vin ???
    By MPTNB in forum Passat - Archive Topics
    Last Post: 17-08-2006, 01:08 PM
