Thread: Glow plug issue! Advice needed!
Results 1 to 9 of 9
  1. Glow plug issue! Advice needed!
    Jan 2011
    Magherafelt
    My A4 Avant (2006 BRB 115BHP 1.9TDi) was in for a full service recently and shortly afterwards the engine management light came on.
    I took it back to the garage and he plugged in the OBD diagnostic machine, which diagnosed the problem as a faulty glow plug (bank 1).
    I used NGK glow plugs and replaced the faulty plug with another NGK.
    A week or so later the car threw on the engine management light again.
    I took the car back to discover that I had another faulty glow plug (bank 2 this time).
    I assumed by this stage that I had came across a batch of faulty NGK plugs so I decided to remove them all and replace with Bosch plugs.
    Again, a few days after fitting the plugs the engine management light came back on.
    Any thoughts as to what might be the problem?
    The only other reason I can think of is a faulty glow plug relay...
  2. Re: Glow plug issue! Advice needed!
    Jan 2009
    towcester northants
    the bridge loom is shot
    replace the loom to cure this fault its common on vw/seat 1.9pd
  3. Re: Glow plug issue! Advice needed!
    Jan 2011
    Magherafelt
    Cheers for the reply mate.
    The car's going in on Monday morning to have the timing checked on the glow plug relay.
    If it's staying on it could be burning the plugs out.
    Can you tell me more about the bridge loom and what it does?
  4. Re: Glow plug issue! Advice needed!
    Jan 2009
    towcester northants
    the bridge loom is the plastic loom that connects all the glow plugs
    these fail and cause the problem you seem to have
    replace the loom it will join in main wiring harness somewhere and you just cut the old one out
  5. Re: Glow plug issue! Advice needed!
    Jan 2011
    Magherafelt
    Many thanks for the reply again mate.
    Are these expensive?
  6. Re: Glow plug issue! Advice needed!
    Jan 2009
    towcester northants
    if i can remember they are about £45
    only avail from vw/audi parts
    dont go secondhand as it may have same issue
  7. Re: Glow plug issue! Advice needed!
    Jan 2011
    Magherafelt
    Thanks again!
    I'll let you know how I get on.
  8. Re: Glow plug issue! Advice needed!
    Jan 2011
    Magherafelt
    Problem sorted.
    Dealer sent wrong plugs!
  9. Re: Glow plug issue! Advice needed!
    Jan 2011
    Magherafelt
    They sent the newer 5v plugs.
    My car runs on the older 12v ones!
  1. Please Help glow plug
    By nooney in forum New Member Introductions
    Last Post: 22-09-2011, 09:23 PM
  2. 2002 2.5 tdi Can Belt changed issue - Advice needed please
    By f2raf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 04-08-2011, 01:30 PM
  3. Replies: 6
    Last Post: 08-02-2011, 03:28 PM
  4. Glow plug light still on after new plug fitted
    By mkvrnn in forum Golf MK5 - 2004 - 2009
    Last Post: 03-01-2010, 11:15 PM
  5. brake lights/glow plug light issue
    By mattpone in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-10-2008, 09:34 PM
