Thread: Still smoking after turbo change.
Results 1 to 10 of 11
  1. Still smoking after turbo change.
    I have a 1997 Passat TDI and have just fitted a new turbo after the shaft on the old one snapped and drained the engine of oil. Can anyone tell me if it is common for the engine still to smoke after the change. All the pipes were cleaned of oil as was the intercooler. The oil level does not appear to be dropping. Could it just be burning of oil from exhaust. If so does anyone how long this should take.
    Mar 2012
    Newtown Mid Wales
    Most likely from exhaust. Will take ages to burn off im afraid! :0(
  3. Re: Still smoking after turbo change.
    Thanks for that. Hardly noticeable when driven steady but a little heavier when you put your foot down. Will keep an eye on it but car drives well with no performance problems.
    Mar 2012
    Newtown Mid Wales
    One of my mates drove up the road after a land rover turbo let go and filled the exhaust. The whole road came to a standstill. Red faced on the way back! Ha ha
  5. Re: Still smoking after turbo change.
    Theres a good clip on youtube of a Landrover Turbo going. Definately worth a watch. I don't think I have anything to worry about, the new turbo seems to kick in fine.
  6. Re: Still smoking after turbo change.
    Apr 2009
    It can take 150 miles to stop smoking, but be aware that the boys in blue can issue
    a prohibition order, which means its not permitted on the road until the emissions
    are tested and are within accepted levels, and thats a new exhaust system.
    Regards
    Jim
    Still Crazy After All These Gears
  7. Re: Still smoking after turbo change.
    Hampshire
    I had a turbo go on a Saab 900 years ago. Theproblem is that load of oil gets dumped in the exhaust so after you change the turbo there is still loads of oil in the exhaust system. Which then burns off.
  8. Re: Still smoking after turbo change.
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    Many years ago, I changed the turbo on a Leyland National bus, which had put a lot of oil into the exhaust. On road test in the dark, pulling hard up a long hill, I had about a three foot flame out of the (sideways facing) exhaust. Certainly made the cars coming the other way move over! Seriously, you need to go for a long hard drive to clean out the exhaust.
  9. Re: Still smoking after turbo change.
    sorry for leaving it so long to reply to everyones advice. I'm still a little cautious about the car. Have taken it out for a few short runs and given it some welly, and still feel uneasy about the smoke. As I said in an earlier post the car shows no smoke when driven normally, but when I keep my foot to the floor it leaves a trail of smoke behind but its not thick smoke. Oil level is staying the same as is the water.
    I can't think there would anything else wrong. I was originally concerned there could be problems with the rings, but I think that would produce smoke even when driven normally. Will just keep driving.
  10. Re: Still smoking after turbo change.
    Jul 2010
    Monmouth, Wales
    7 Post(s)
    If it's not using oil, then keep driving it. It should clear eventually.
  1. Question Turbo change
    By Freakydeaky in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2009, 04:19 PM
  2. Please Help TDI 110 turbo replaced but still smoking
    By martinA4passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-06-2008, 10:07 PM
  3. TDI Smoking, Reduced MPG and Turbo 'Rasping'
    By branchespark in forum Golf MK4 - 1999 - 2004
    Last Post: 11-05-2008, 08:29 AM
  4. 1.8T turbo issues after smoking
    By ginge in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 06:22 PM
  5. Bora TDI Turbo/smoking issue
    By dles1966 in forum Bora - 1998 - 2005
    Last Post: 04-10-2006, 09:54 PM
