Thread: Indicators stuck on
  1. Indicators stuck on
    Nov 2011
    Liverpool
    I hope someone can help me.
    Waiting to turn right at a set of lights, indicators flashing, they suddenly all came on and stayed on, not flashing but permanently illuminated. I removed the flasher relay fuse #2, and the still stayed on, then removed the hazard flasher relay and they went off. I could continue to then use the indicators but they flashed really quickly with a noticable clicking sound from the hazard switch.
    Does this mean the hazard relay is caput, and if so is it part of the switch?
    Thanks in advance folks.
  2. Re: Indicators stuck on
    Yes probably a failed unit. Time for a new one. Regards Peter
  3. Re: Indicators stuck on
    Nov 2011
    Liverpool
    Update
    A little trip to Liverpool Audi, £40 lighter. Swapped the unit over but still have the problem of all indicaters perminantly on but when the hazard relay fuse is removed the lights go off, allowing me to use the turn signals ok but no hazards!!
    Does anyone know if I need to reset anything via the cars computer or if there is another relay somewhere?
  4. Re: Indicators stuck on
    Jul 2010
    Preston, UK
    Sometimes a little contact cleaner on the contact ring on the column can help - spray it on and go from lock to lock with each indicator switched on to clean contact ring - they get gunked up with dust and fluff.
  5. Re: Indicators stuck on
    Nov 2011
    Liverpool
    I have tried contact cleaner, but still no joy.
    Would anybody know if the indicators are controlled through the unit in the passenger footwell? If so I fear this may need replacing.
  6. Re: Indicators stuck on
    You need the cct diagram and a meter. One possibility is the the cental locking unit has a fault and there is a signal that pulses all flashers when you lock unlock the car. There is also a signal from the Airbag control; unit that puts the hazard flashes on if the airbags go off. PM me for the diagrams. Regards Peter
  7. Re: Indicators stuck on
    Nov 2011
    Liverpool
    Thanks for the offer of the diagrams Peter, but I would not have a clue what I was doing with them!
  1. Please Help indicators
    By bs3 golf in forum Golf MK3 - 1993 - 1999
    Last Post: 24-10-2010, 07:26 PM
  2. Nearside indicators stuck on continuous
    By rsmcgoo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-09-2010, 08:26 AM
  3. Water, wet carpets, indicators stuck on, remote locking duff
    By TonyWilk in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 26-08-2010, 10:06 PM
  4. No indicators (HELP)
    By custom24 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 28-03-2010, 07:05 PM
  5. Fuel gauge stuck and brake stuck !
    By Satch in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 30-01-2009, 03:40 PM
