Thread: Oil change on variable service
Results 1 to 9 of 9
  1. Oil change on variable service
    Jun 2010
    chelmsford UK
    Hi all
    My A6 quatro 2.7tdi is currently on variable service. It was serviced 8weeks ago.
    1.If I do an oil and filter change in 12months what will happen to the service indicator will it go up for "miles to next service"?
    2. Does the service indicator go up and down during the service period . Mine is currently saying 600+ days and 8600miles to next service. I was expecting it to say more. I intially did a 500mile round trip straiught after the service and since then I have always done 30-40m trips although it does sit in the garage for probably 4 days a week. I have done about 1000miles now
    Many thanks for any advise
    Mab
  2. Re: Oil change on variable service
    Oct 2010
    Berkshire, UK
    Variable servicing depend on many engine parameters like miles driven, total, hours usage, number of bonnet openings and oil quality/clarity. You can switch between one or the other using VCDS. When dealers service your car, they reset these counters in the cars computers. so to answer your questions in order.
    1.1.If I do an oil and filter change in 12months what will happen to the service indicator will it go up for "miles to next service"? - It will keep ticking down until you reset the computer. You are supposed to do both things together (oil change and computer reset). The behaviour will depened whether your car thinks it is on annual or variable servicing. if you wish to change the type of servicing, you need to change this by adaptation of the various computers using VCDS
    Does the service indicator go up and down during the service period . Mine is currently saying 600+ days and 8600miles to next service. I was expecting it to say more. I intially did a 500mile round trip straiught after the service and since then I have always done 30-40m trips although it does sit in the garage for probably 4 days a week. I have done about 1000miles now - Days go down to 0, or service now/overdue.. Same applies to miles
  3. Re: Oil change on variable service
    Jun 2006
    Also keep in mind what you are trying to achieve. By that I mean if you just want to do a DIY oil change inbetween the garage long life ones then there's no need to reset the computer as you are just adding an interim change of your own.
    If however you are doing all the services yourelf then you would be wise to invest in a VCDS from Ross-Tech as at some stage you will need to be resetting the SRI properly.
  4. Re: Oil change on variable service
    Jun 2010
    chelmsford UK
    So if after the service indicator is saying 8600 miles to next service and I have done around 900miles now do you this its been set up on fixed service rather then varaible?
  5. Re: Oil change on variable service
    46 Post(s)
    Quote Originally Posted by mabaudi View Post
    Yep sounds like fixed. Fixed is roughly 9000-10000 miles.
  6. Re: Oil change on variable service
    Jun 2010
    chelmsford UK
    Thanks Chris. I did wonder if that was the case as the original dealer(Approved Audie) had it swicted to fixed when I purchased it and they did the service before collection. Is it to late for my current garage to switch it now?
    Many thanks
    M
  7. Re: Oil change on variable service
    46 Post(s)
    You could get it changed, but your garage would have to change the indicator settings to compensate for the mileage you already covered since the service.
    What mileage do you do per year?
  8. Re: Oil change on variable service
    Jun 2010
    chelmsford UK
    I do about 7000m miles a year. My journeys are always a minimum of 50miles per trip. Monday to Fridays its sat in the garage
  9. Re: Oil change on variable service
    Sep 2011
    Lurking over a keyboard ...
    I have owned my car 8 months, did first oil change in Jan 12. Car was set to flexible, I thought fixed would be right for it as mostly local driving. Originally computer recommend service in 9000 miles then slowly it crept to over 11000 and has now climbed to 16000 miles with the recent months worth of mway driving...
    I will still do oil change in Jan 13 but good experiment to see what it recommends....
  1. Fixed vs. Variable oil change intervals
    By gazza57 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-12-2011, 09:07 AM
  2. Variable Service Interval
    By John140 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-03-2011, 09:18 AM
  3. A3 variable service
    By dumpee in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-09-2009, 07:30 PM
  4. Question Difference between Variable Service 1 and 2
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-12-2008, 03:57 PM
  5. Reset Oil Service milage after oil change
    By onzarob in forum VCDS - General Questions
    Last Post: 28-06-2008, 08:34 AM
