Thread: golf 4 gt tdi power loss help, (PLEASE'S)
  1. Unhappy golf 4 gt tdi power loss help, (PLEASE'S)
    hi every one in a new to the site.
    need help.I have a mk4 golt gt tdi(110),
    im geting no faults on vag com at all,after 2500 rpm it has no power,im thinking its a air/pressure problem can any one shed any light on the problem for me please.
  2. Re: golf 4 gt tdi power loss help, (PLEASE'S)
    Gloucester
    If you're getting a REALLY loud whistling noise then i'd guess it's a leaky pipe but other than the obvious excessive smoke (Poss blown Turbo) I have no idea
    Hope it's something small and cheap
    Ex Golf GT TDi 150. Then an Evo 8. Then a Honda S2000. Now an Evo 5 (and a little pug 106)
  3. Thumbs up Re: golf 4 gt tdi power loss help, (PLEASE'S)
    It sounds like it could be the air mass meter. Their not ridiculously expensive (about £100 or so) you can fit them yourself but for what extra it will cost I would get a garage to do it for u.
  4. Re: golf 4 gt tdi power loss help, (PLEASE'S)
    Mar 2007
    Greater Manchester
    £100??? Blimey, I'm sure they were about £65 last time I checked.
    If you're going to buy one, be sure to find out if its just the sensor component or the full housing unit. You may just be able to get away with just giving a good clean.
    Search for threads on here and you will surely find some help on MAFs. Including how to test/diagnose to see if your MAF is at fault. Also some excellent threads on how to remove and replace your MAF.
  5. Re: golf 4 gt tdi power loss help, (PLEASE'S)
    Canada
    I got a quote for £54 from VW for a new MAF, i paid £40 for one off ebay, which has been ok.
    Try unpluging the maf and the car should rev further and smoother, but it will stil not be full power, but a good test.
  6. Re: golf 4 gt tdi power loss help, (PLEASE'S)
    Quote Originally Posted by onzarob View Post
    YES,its the MAF,just unpluged it and its a lot better,so im on the lok out for a new one now
    cheers eveyone for your help
    I shall return shortly to let you's know how the new MAF went
  7. Re: golf 4 gt tdi power loss help, (PLEASE'S)
    Apr 2007
    Lancashire
    If you are not getting any faults on vag-com, can you explain the power loss in more detail?
    Can you hear the turbo spooling up?
    Does the power tail off, or cut off abruptly?
    What revs can the car reach, and does it still accelerate very slowly after 2500rpm?
    Do you have any smoke?
    Have you had any work carried out on the car recently?
    Sounds like the turbo is not working at all, but you should be throwing some 'manifold pressure' codes if it is not?
    Check timing, injected quantities, temp readings, maf, cat, n75, map, throttle position sensor etc.
    Make sure the vnt actuator rod is moving freely.
    + obvious things like blocked fuel/air filters, n75 pluged in + pipes atteched, turbo actuator hose attached, maf connected etc.
    Can you post some vag-com measurements.
  8. Lightbulb Re: golf 4 gt tdi power loss help, (PLEASE'S)
    Mar 2007
    Greater Manchester
    Quote Originally Posted by ini View Post
    Some of things above I wouldn't know how to check, where to find them or what they are.
    Any chance we can get a How To sticky with pics.
  1. power loss
    By john grout in forum Passat - Archive Topics
    Last Post: 21-01-2008, 01:14 PM
  2. golf mk4 loss of power... help please
    By tannerzxr in forum Golf MK4 - 1999 - 2004
    Last Post: 06-09-2007, 04:41 PM
  3. Golf TDI Mk3 loss of power
    By Mark Scruby in forum New Member Introductions
    Last Post: 31-08-2007, 10:11 AM
  4. Golf TDI Power Loss
    By donnytella in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 20-07-2007, 10:31 AM
  5. Sick Golf GT 150 Pd TDi. Power loss, poor idle
    By lchris21 in forum Archive posts
    Last Post: 17-12-2006, 09:02 PM
