Thread: Seat Ibiza ECU Change
  1. Seat Ibiza ECU Change
    Feb 2012
    Chicacha filetg
    Hi all,
    car in and the following codes are up on it:
    P1517, P1558, P1680
    I got a new main relay and going to try it tomorrow, also got a new ecu for the car but no key (is this needed) how do I go about reprogramming the 2nd hand ecu to this coding will be done with autoboss v30 not vcds as the laptop at the min is down and away being repaired!!! hopefully the relay will sort it just need heads up incase it doesnt
    thanks all
  2. Re: Seat Ibiza ECU Change
    May 2010
    Devon England
    petrol/diesel? engine cc or better still engine code? i dont use P codes as there gen codes, would be better if you had vcds codes
  3. Re: Seat Ibiza ECU Change
    Feb 2012
    Chicacha filetg
    Its a 2001 1.2 3 cylinder petrol - not sure of the engine code will check this morning. The v30 is only pulling the P codes not the vcds ones - what a time for the laptop to go **** up!!!
  4. Re: Seat Ibiza ECU Change
    Feb 2012
    Bristol
    Normally the ECU has to be coded to the immo... i used vagcom to to do mine when my ECU packed up a couple of months ago...
  1. Ibiza drivers seat
    By bigwayne in forum Ibiza - Cordoba
    Last Post: 09-11-2009, 11:52 AM
  2. my seat ibiza mk3
    By adam1.4biza in forum Show 'n' Shine - Post your efforts here
    Last Post: 03-06-2008, 12:55 PM
  3. Seat Ibiza
    By P Groves in forum New Member Introductions
    Last Post: 28-05-2008, 03:01 AM
  4. Seat Ibiza 1.4 2002
    By ibiza52 in forum Ibiza - Cordoba
    Last Post: 24-02-2008, 03:20 PM
  5. new seat ibiza
    By ianbarrows in forum Ibiza - Cordoba
    Last Post: 27-08-2007, 09:37 PM
