Read a lot, changed the ECT sensor, waiting for a relay 109 on order.
I don't think my problem is the aux heater system as i get smoke even if i disconnect that.
So unburnt diesel on first start up is the cause of that and i confirmed its not coming from the aux heater exhaust.
I was able to start the car by removing the act sensor to let the glow plugs run on, this isn't working now. Lucky I got myself back from scotland before the old beast decided not to start at all anymore.
I've been losing the clutch but have been able to pump it back up by adding fluid and pumping the brake fluid. The more you drive the more the clutch slips away then you have to have a pumping session which make you look like a prat.
Thats developed into clutch peddle wiggle when its depressed and you are steering at low speeds, i,e reversing, setting off.
probably need pointing to the right fault finding/troubleshooting posts.
