Thread: Passat B6, MFD2, USB, Playstation?!
  1. Passat B6, MFD2, USB, Playstation?!
    Feb 2012
    Coventry
    Hi guys, first post!
    Last week I picked up a sexy 2006 2.0 sport and I've got a few things planned for it.. Firstly...
    I've got an MFD2 with factory fitted CD Changer in glove box.
    However, I want to add a Aux and USB port, but keep the CD changer if possible, is this possible with this?
    After looking at the diagram they have shown, it seems possible, which then got me thinking...
    If I put a 3.5mm splitter (this) in the aux port, can I then have one cable to my phone, and one to a playstation using a 3.5mm to AV cable like this?
    I'd then power the playstation using this?
    Right?! :s
  2. Re: Passat B6, MFD2, USB, Playstation?!
    Feb 2012
    Coventry
    Bump?
  3. Re: Passat B6, MFD2, USB, Playstation?!
    Dec 2007
    Bedford
    With the item you have posted it looks like you can't use your CD changer as you will have to unplug the cable to insert the grey one shown on the system.
    The only way to do it is a bit more expensive.
    You can get a Dension Gateway 300 along with a CD Changer Retention Kit.
    The Gateway 300 will give you a proper dedicated iPod interface where you can change tracks via the steering wheel or head unit and give you track details on the dash.
    It also have a 3.5mm jack input and USB.
    Otherwise the item you posted is a really good price if you want to get rid of your CD Changer
    2017 Audi A5 (B9) Coupe 2.0 TDI S-Line Quattro S Tronic
  4. Re: Passat B6, MFD2, USB, Playstation?!
    Dec 2007
    Bedford
    Ignore what I said mate... Just looked at the wiring diagram on the kit you said and you WILL be able to keep your CD Changer... It is switchable
  5. Re: Passat B6, MFD2, USB, Playstation?!
    Feb 2013
    Bradford West Yorkshire
    Hey have you managed to get this working as I am wondering the same with my passat?
  1. MFD2 into a 2011 Passat
    By cymru001 in forum Passat - B7 Forum - 2011 - 2015
    Last Post: 29-07-2011, 04:04 PM
  2. Question retrofit MFD2 in early passat?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-02-2011, 05:31 PM
  3. Passat Highline USB
    By dan_the_v8man in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 16-02-2009, 12:12 AM
  4. Mfd/Mfd2 in passat.
    By chris494rep in forum In Car Entertainment
    Last Post: 05-08-2008, 11:39 AM
  5. Passat USB port
    By Haji_Doc in forum Passat - Archive Topics
    Last Post: 14-11-2006, 12:46 AM
