Thread: 100,000 miles BMR DPF Engine , what now ?
  1. 100,000 miles BMR DPF Engine , what now ?
    Mar 2009
    So my 2008 SEL 170 ESTATE is on 97k , having a full service history and probably worth not a lot of money for the car, I decided to stick with it till dust shall prevail.
    I have had the injector recall a few weeks back and hopefully the turbo will last another 50k however I would like to do some maintenance as there are a few issues
    I have a knok coming from the drivers side when travelling over uneven surfaces , its very weird and some friend of mine changed 4-6 bushes and a control arm , but that didn't cure the problem , he also done 4wheel alignment but said he wasnt sure to tell me what the problem is , he thinks broken spring or damaged mount , would it be worth changing all our shocks and springs with all new bushes and control arm kit to make it like new ?
    Would a new coilover kit improve anything or go OEM all the way ?
    EGR valve , delete or clean ?
    DPF / Remove ?
    When my lift pump broke I spent a whole sunday trying to get it started , since then I noticed car a bit hesitant as if the turbo had more lag . When I changed my injectors the VW garage said the car is fine just low tire thread
    Sorry about the essay
    Happy Pancake Day
  2. Re: 100,000 miles BMR DPF Engine , what now ?
    DSG4ME Guest
    Try the top strut mounts first.
    Clean it
    Leave it, if it ain't played up yet your obviously doing the right type of driving.
    VW won't admit to anything mate, do a simple thing, undo the battery for an hour and let the ecu reset.
  3. Re: 100,000 miles BMR DPF Engine , what now ?
    Mar 2009
    Quote Originally Posted by DSG4ME View Post
    Thanks !
    Weirdly enough most my driving is under 10 miles in and around London with lots of short journeys
  1. 1999 Passat 1.9 TDI AFN engine 150,000 miles - anything I should be worried about?
    By Scottiedogg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-10-2012, 06:55 PM
  2. 100,000 miles- a happy B7 ownership report- no doom and gloom :)
    By kodkod.84 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-09-2011, 06:45 AM
  3. Can anyone beat 100,000 miles in a B8?
    By DeepSeaBlue in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-07-2010, 03:23 PM
  4. Question Would you service after 4,000 miles?
    By curiousgeorge in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 14-03-2010, 07:18 PM
  5. Question 80,000 miles b5 1.6 what oil?
    By chrismaher2007 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-03-2009, 11:41 PM
