Thread: Emissions Warning Light
Results 1 to 10 of 11
  1. Emissions Warning Light
    Nov 2008
    Leeds
    Got a 55 plate A6 2.7tdi SE.
    Would be a Saturday afternoon and everyone is closed so can't get fault codes read until next week at the earliest but the Emissions light came on for half an hour and having been parked up at the chip shop for 10mins has gone out and so far not reappeared.
    Read the manual as nothing else I can do and can't think of anything else but a motorway drive for 1/2hour over running at 2000RPM to try and clean it.
    Not noticed any loss of power or balck smoke and will check the pipes leading to the DPF tomorrow.
    Any other ideas of things to check in the meantime or why something might be intermittent.
  2. Re: Emissions Warning Light
    Jun 2011
    West Yorkshire
    whats your location? if local, would come out and take a look. Just check your oil level and water. A run on the motorway cant do any harm..
  3. Re: Emissions Warning Light
    Jul 2008
    Sorry to be the bearer of bad news.
    But your swirl flaps / intake manifold runners are probably gone. Same thing happened to my 2.7 TDI 2008 Le Mans. But you must get the codes read to be sure. The warning light comes on if the tolerances wear to above +-2% in the rod endings. And apparently it makes no difference getting them fixed or not as they default in the open position. So worst thing that can happen is engine can be a bit rich at idle. No loss in economy or power. Just a bloody annoying light on the dashboard.
    Had mine "fixed" from an audi dealership only to find out they scammed me.
    You can read more about it by searching for "swirl flaps" or take a look at my posted threads to see what i'm on about.
    Hope its not the swirl flaps - My motor was only under 60,000 miles and the right hand side still went
  4. Re: Emissions Warning Light
    46 Post(s)
    The engine light could mean any number of problems, a fault code will pinpoint the problem.
  5. Re: Emissions Warning Light
    Nov 2008
    Leeds
    Quote Originally Posted by Hyper-Remaps View Post
    Thanks for getting back. Decided on a trip from Leeds to Manchester on the M62. Thought I could stretch its legs. Ha. 50mph limit just about 3/4 of the way. Not pleased. That said no sign of the dreaded emission light all day. After the replies about the swirl flaps etc I'm thinking about chopping the car in asap and getting something newer (ideally b4 the light comes on again) otherwise I'll need a second mortgage. Thanks for your offer of help.
  6. Re: Emissions Warning Light
    46 Post(s)
    Quote Originally Posted by rictic68 View Post
    As I said above, get a fault code scan done before you sell/change etc.
    You never know, it could be something simple.
  7. Re: Emissions Warning Light
    Jul 2008
    rictic
    On my a6 the light constantly came on and off aswell. I found that driving it hard would turn off the light for a while but the pesky bugger always returned - it can't really do any damage to the engine but the light is bloody annoying.
    get it scanned though
  8. Re: Emissions Warning Light
    Feb 2009
    Glasgow UK
    I had " emmissions workshop" message appear on my wifes Passat some time ago.
    We looked at various issues, the EGR valve kept coming up in htreads as being clogged, so we took that off and cleaned it up ( it wasn't as bad as some have said theirs was - but we had it off so cleaned it anyway )
    At this point, kinda fumbling around tbh I also checked the air filter ( supposedly changed at previous services - looked to be the original, bloody filthy!! ) so changed it out.
    The dash light went out for a day or so, then came back.
    I did more research here on this forum and found numerous complaints about the coolant temp sensor. I checked and found I could buy one from Ebay for £6 delivered and my mechanic took £10 to fit it in around 15 mins.....problem solved many months ago and the dash light has never returned.
    I only post this to confirm what A6 Chris says.....it could be something very cheap and very simple.
    Get the codes if you can, do as much research here / elsewhere as you can and I'm sure you'll get to the bottom of it soon
    Good luck
  9. Re: Emissions Warning Light
    Nov 2008
    Leeds
    Thanks for the replies. Should be getting the codes read tomorrow afternoon at work (providing the guy remembers his gear). The light hasn't reappeared since Saturday. Interesting about the water coolant sensor.
  10. Re: Emissions Warning Light
    Feb 2009
    Glasgow UK
    Hey there,
    here's the link to my thread on this for my wifes passat ( it has a few links within the link, may be helpful )
    https://www.vwaudiforum.co.uk/forum/s...p-dash-message
    Good luck my friend and hope to hear
    Jim
  1. Emissions Warning Light is on
    By pld118 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 16-05-2012, 10:46 AM
  2. Emissions warning light
    By andyc12 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-10-2009, 02:08 PM
  3. Question Help? emissions warning light
    By bjardine in forum Chat - Anything with wheels
    Last Post: 08-10-2008, 08:06 AM
  4. ABS Warning light, Emissions light, window.......
    By savs in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-07-2008, 03:06 PM
  5. Emissions warning light?
    By the stig in forum TT - 8N Forum - 1998 - 2006
    Last Post: 21-11-2007, 01:22 PM
