Thread: radio code
  1. radio code
    hi
    i have a vw passat 2001 under the battery there is a pool of weter. i have been told the drain holes will be blocked. but to do this i will need to disconect my battery. will i need the code once it has been replaced? the radio has a red flashing diode i have read the booklet but not sure whether to remove battery. thanks for ant help/replies in advance.
  2. Re: radio code
    Jun 2007
    ireland
    Hi, I Did The Drains On 2 Passats Today Removed Battery,no Problems:d
  3. Re: radio code
    thanks ill try it tomorrow
  4. Re: radio code
    niallyoc Guest
    Nope you shud't need it, instead of using a manual code "convenience" coding is used. When power is reconnected the radio synchs persumably with the ecu so it can only be used in one car. Worked spot on when i disconnected my battery anyways..
  5. Re: radio code
    niallyoc Guest
    Oh ya theres two drain holes one under the battery and one under the servo, both need to be cleared or water can leak in the air outlets passenger side on RHD models at least. This link may be handy http://www.weirdlittlebiscuit.com/passat/leak/index.htm
  1. VW Radio Code
    By ian999 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-05-2007, 09:52 PM
  2. Concert Radio - can code be disabled?
    By gary_m in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-02-2007, 09:47 PM
  3. Inputting Radio code
    By ferrispedro in forum Touran - Sharan - Caravelle
    Last Post: 01-02-2007, 06:45 PM
  4. Audi Radio Code
    By eribar in forum Archive posts
    Last Post: 30-06-2006, 11:07 AM
