Thread: injector madness
  1. injector madness
    Aug 2011
    birmingham
    hi everybody i need some one advice please because my golf mk5 2.0 tdi 140 bkd engine code has made me headless, has any one came across this puzle ? few month ago my car died on me on the road i took it to my mechanic then he done diagnostick check on it using vcds dealer level software came up as harniess injector or wirring lum voltage to high , i cant remember ecxact word , anyway what he did was disconnect the injector wiring lum from the back of the head and clen it with some lubricant and he spried some easy starter on the intake pipe , car start with no problem ... it was ok and last me almost three month then samething happn again , he said you got to change injector lum which sit in side clyinder head , he changed that everything seems fine , now i past another three month , last week died on me again , my mechanic done his reutine check and said is got to be injectors , so what he did was took all injectors out and i took it for bench test , place call carwood , result came bk all of them failed as they diliver too high , i bought some seconh hand one for £100 each now still no result , changed high pressure pump still nothing and i know its fuel relating issue because when you spray with easy start it start till burn off the easy start and then cuts off , fuel coming to fuel filter fine , timing is ok , inector paulsing perfect , can any one help please as id drive me mental, i dont know what to do with it . thank you for any tip ,
  2. Re: injector madness
    Aug 2009
    Buckshaw Village
    You're not from around these parts are you pal ;-)
    2013(63) A3 Sportback. 2.0 tdi. 150. Ice Silver. Rear parking. Cruise.
  3. Re: injector madness
    Up North
    No, according to Google Maps, he's 106 miles from you via the M6. Maybe the full stop and shift keys are broke on his keyboard. And the return key. And the spell check.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. Stateside madness
    By ijetta in forum Bora - 1998 - 2005
    Last Post: 21-09-2010, 09:29 AM
  2. '99 A6 locking madness!
    By jimp in forum New Member Introductions
    Last Post: 11-02-2008, 11:52 PM
  3. '99 A6 locking madness!
    By jimp in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 11-02-2008, 10:08 PM
  4. seat madness
    By STORM 2 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 27-09-2007, 05:30 PM
