Thread: airbag light when clutch is pressed?
  1. airbag light when clutch is pressed?
    Aug 2009
    ireland
    hi guys
    i got an airbag light on my 06 passat, so did a scan with vcds came up resistance high passenger seat and another code 00590 saying there is a short to ground.
    i took off the connectors under passenger seat and soldered them together and heat shrunk them, then reset the fault codes and the airbag went off, until i pressed the clutch. so checked fault codes again and the 00590 was there again so went to the measuring block for the passenger seat airbag and noticed every time i press the clutch i would lose the resistor reading for a second and the airbag light would pop on again.
    so i thought there must be a wiring loom getting caught on the clutch pedal,so had a look and there was no wires anywhere near the pedal , so now im totally lost.
    anyone have any ideas
    thanks in advance
  2. Re: airbag light when clutch is pressed?????
    DSG4ME Guest
    Have you had the radio surround off, if so if you disconnected the wires it will need re-setting, you can also turn off the bags by the glovebox, so if it's just the light under the radio this is probably it.
  3. Re: airbag light when clutch is pressed?????
    Aug 2009
    ireland
    no, its the light on the dash, when you reset it with vcds it turns off but as soon as the clutch is pressed is back on straight away. any ideas???
  4. Re: airbag light when clutch is pressed?????
    DSG4ME Guest
    Only thing that comes to mind is the pedal making a circuit by going metal to metal with something, I would look under the dash to see if any wires are moving about as you press the pedal in, or if any wires seem damaged.
  1. Mk4 gt tdi clutch grinding when clutch pressed half way
    By JIBAJABA in forum Golf MK4 - 1999 - 2004
    Last Post: 21-01-2011, 05:33 PM
  2. Car won't start with clutch pressed
    By dpshonko in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-12-2009, 03:59 PM
  3. Clutch Pedal making "Clicking" sound when pressed down
    By Eire12 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-05-2009, 04:26 PM
  4. Please Help Polo 96 stalls if clutch pressed when revs is above 1000
    By catnipsta in forum Polo - Derby - Lupo - Fox
    Last Post: 29-04-2009, 06:31 PM
  5. clutch fails when brake pressed
    By expensive bora in forum Bora - 1998 - 2005
    Last Post: 10-04-2009, 06:46 PM
