Thread: Indicators not flashing & window failed
Results 1 to 10 of 10
  1. Indicators not flashing & window failed
    Jun 2011
    Rochdale
    My indicators don't flash, they come on, so I manually flick up & down to indicate. Checked rear bulbs all fine, maybe relay? Where is it & how do I access please? Also nr side Elec win started jamming, not fully closing then would t close at all. Just hear crunching sound. Took of door card, pulled window up. Temp fix.
  2. Re: Indicators not flashing & window failed
    Jan 2006
    PRESTON, LANCS
    Window problem sounds like broken regulator wire/cable-. Unrelated to your indicator problem .
  3. Re: Indicators not flashing & window failed
    Jun 2011
    Rochdale
    thank you, anyu ideas on the indicator? ive found a relay on ebay, its the warning light button itself thats pulled out of the dash, has a relay behind it, the seller seems to think its the same for the indicator, even though my hazard lights flash ok, my indicators dont, vcds dont bring up any code
  4. Re: Indicators not flashing & window failed
    Mar 2008
    High Wycombe
    The indicator relay is the hazard light switch. There's 2 relays - one for hazards, one for indicators, which is why the hazards still work.
    It's a common problem, and a quick search on here should find a link to a 'how to change the hazard switch'.
    From memory, I think it's pretty much:
    Prise out the trim surrounding the switch
    undo a couple of screws holding the switch in
    unplug switch
    reassemble
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  5. Re: Indicators not flashing & window failed
    Jun 2011
    Rochdale
    Thank you, will have a go later
  6. Re: Indicators not flashing & window failed
    Jun 2011
    Rochdale
    problem solved, took it out to check no of pins & product code, used a screwdriver tip to rub the ends of the contacts, a good few blows to blow away any dust, popped it back in and hey presto! indicators are working fine again! Im pleased i read this forum though as you need to hold tight on to the plug you detach on the back as otherwise it will disappear into the abyss.
  7. Re: Indicators not flashing & window failed
    Jun 2011
    Rochdale
    Anyone any idea where to start with fixing the window? problem occurred to nr side Elec win started jamming, not fully closing then would not close at all. Just hear crunching/churning sound. Took the door card off and, manually pulled window up. Temp fix.
  8. Re: Indicators not flashing & window failed
    Mar 2008
    High Wycombe
    The window issues sounds like it's either going to be frayed wires gettign stuck (this is less common on this forum), or cracked blue plastic clips which hold the glass to the wires (this is quite commonly mentioned here, and I think the clips are only a couple of pounds from an Audi dealer). Someone recently said you can replace the clips without removing the whole window regulator, but I suspect you'll need small hands to do that.
    2002 Passat 1.9tdi
    2004 A3 2.0 FSI
  9. Re: Indicators not flashing & window failed
    Jun 2011
    Rochdale
    Quote Originally Posted by NickPicks View Post
    thank you for your reply, once i remove the door card, which part of the door am i looking at to view the blue plastic clips?
  10. Re: Indicators not flashing & window failed
    Ayrshire, Scotland
    18 Post(s)
    There are 2 found at the bottom of the glass, they clamp onto the glass and into the guide rails with the cable going through them, with the door card off & door open lower the window approx half until you can see the lower part of the glass window, inspect the cable that goes throught the blue slider which pulls it up and down, there is a nipple on the cable trapped in the clip to pull it, the clips can break right at this nipple allowing excess movement and hence the glass goes up un even and jams
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  1. Replies: 1
    Last Post: 20-07-2008, 09:36 PM
  2. Please Help Indicators and hazard lights completely failed
    By 98passat in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2008, 03:12 PM
  3. Quick flashing indicators.
    By Coastie in forum 80 - 90
    Last Post: 14-12-2007, 04:03 PM
  4. Indicators not flashing!
    By misswhiz in forum Audi A3 - Archive Topics
    Last Post: 22-06-2007, 11:05 AM
