Thread: clutch slipping on 0n b5.5
Results 1 to 10 of 11
  1. clutch slipping on 0n b5.5
    Sep 2009
    northumberland
    High Ive recently purchased an 05 highline 1.9tdi 130 with high miles , the clutch pedal is biting at the very last and i suspect the clutch is starting to slip {ouch} Do i need to purchase a full kit ie:dual mass flywheel ect or can just the clutch plate just be changed and at what sort of prices am I looking at ? The car still drives and im now not using it until ive resolved the issues incase of more damage !
  2. Re: clutch slipping on 0n b5.5
    Apr 2009
    First of all, you need to establish if the clutch is actually slipping or not, if not, a high-biting clutch
    can last for ages.
    If it is slipping, then its best to replace the clutch-plate/pressure-plate/thrust-bearing and DMF.
    Prices will vary for both parts and labour, so shop around.
    Regards
    Jim
    Still Crazy After All These Gears
  3. Re: clutch slipping on 0n b5.5
    Sep 2009
    northumberland
    Thanks for fast reply jim , Ill test it out properly as ive only drove it once ! othe query I have is the engine and gearbox type on my vehicle im not to sure which they are ? I took the engine cover off and checked block and saw RAU 6 But on the body vin tag it states AWX 1853 ? So is the engine AWX or RAU 6 I sumise ill need to know before I purchase the clutch parts ?
    Regards Kev.
  4. Re: clutch slipping on 0n b5.5
    Sep 2009
    northumberland
    Regards Kev.
  5. Re: clutch slipping on 0n b5.5
    Norfolk
    AWX is the engine code
  6. Re: clutch slipping on 0n b5.5
    Sep 2009
    northumberland
    Thanks martin , ps: great imformation on your website link very handy indeed !
  7. Re: clutch slipping on 0n b5.5
    Apr 2009
    Quote Originally Posted by aceventura View Post
    Regards Kev.
    Most motor factors just need the reg number, but its handy to have the
    engine, box and vin numbers, also 5 or 6 speed.
    BTW What mileage is on the car?
    Regards
    Jim
  8. Re: clutch slipping on 0n b5.5
    Sep 2009
    northumberland
    Done a hugh 160k but has been serviced regulary just had new new belts tensioner wheel ,filters ,brakes ect but i guess the clutch has been in since new !
  9. Re: clutch slipping on 0n b5.5
    Apr 2009
    That's not too bad, plenty of life left in her yet!!
    It's probably been driven carefully, or the clutch would have given-up a long time ago.
    Regards
    Jim
  10. Re: clutch slipping on 0n b5.5
    Sep 2009
    northumberland
  1. S3 clutch slipping ??
    By gbrad2x in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-06-2011, 08:40 PM
  2. Please Help Clutch Slipping
    By A4sport1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-06-2011, 07:58 PM
  3. Please Help Slipping Clutch?
    By mdjsa3 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 10-04-2011, 02:21 PM
  4. help!! clutch slipping
    By inka2k2 in forum Golf MK4 - 1999 - 2004
    Last Post: 02-03-2009, 01:56 PM
  5. Slipping Clutch
    By DaiP in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-01-2008, 09:46 PM
