Thread: Audi a3 idle Problems.
Results 1 to 8 of 8
  1. Audi a3 idle Problems.
    May 2011
    uk
    Hi all, got a hold of an a3 last week, took it for test drive seemed fine, so bought the car, about 15 mins into the journey home, every time i stopped at light ect the car would cut out, so i took it too a garage had diagnostic done that came back with 3 faults, throttle body, mass air flow, and speed sensor (speed doesn't work).
    So i replaced the throttle body and mass air flow and its still the same!! i dont want to pay for more diagnostic has the costs are already starting to rise. So wondered if anyone had similar problem or could offer any advice?
    Basicly the car starts a little ruff, runs at about 1500rpm then drops after a min or two, then after 10 mins of running just cuts out starts back again after a little persuasion then cuts out? Could it be another sensor? ecu? electrical? would the ecu need to be reset after i replaced the parts??, no engine management light on.
  2. Re: Audi a3 idle Problems.
    May 2010
    Devon England
    what engine and is it petrol or diesel? your speedo doesnt work? ive had this before and its been a broken wire under the battery, also there is a fuse in the fuse box inside that also does the speedo but isnt marked as doing it, if and im guessing here, its a 1.8 turbo then it could be the ign module that is bolted to the side of the air box, but with out knowing what engine you have this is guess work mate
  3. Re: Audi a3 idle Problems.
    May 2011
    uk
    hi sorry for not stating its a 1.6 petrol.
  4. Re: Audi a3 idle Problems.
    May 2010
    Devon England
    Quote Originally Posted by world-change View Post
    I havent had much to do with them, ive PMd crasher asking him to see what his thoughts are, sorry i cant help out more mate, but the speedo fault will more than likely be a broken wire under the battery
  5. Re: Audi a3 idle Problems.
    May 2011
    uk
    hi thanks for the reply appreciate it.
    Still not got to the bottom of it if anything changes will post here in the mean time if anyone else has had similar issue i would appreciate any feedback.
  6. Re: Audi a3 idle Problems.
    May 2011
    uk
    A little update, went to the car this morning and it had a little backfire whists starting?
  7. Re: Audi a3 idle Problems.
    May 2011
    uk
    Update, I've replaced the throttle body and the MAF still the same? car is now starting to burn a hole in my pocket. does the ecu need to be reset after this job?
  8. Re: Audi a3 idle Problems.
    May 2011
    uk
    Update, it was crank sensor and lambard sensor. all done.
  1. 1996 Audi Cabriolet 2.6E Idle Problems
    By micktuggy in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-08-2009, 11:10 AM
  2. Audi A4 1.8 Idle and Dash problems
    By pologt in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-11-2007, 02:30 PM
  3. Audi Cabriolet idle/power problems...
    By benhoffmann in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 18-09-2007, 10:14 AM
  4. please help - idle problems
    By Cyber_A3 in forum Audi A3 - Archive Topics
    Last Post: 21-08-2007, 10:13 AM
  5. Audi A6 2.6 V6 Idle Problems
    By WADZ000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-02-2007, 07:42 PM
