Thread: A6 Avant (C6) Armrest removal
Results 1 to 9 of 9
  1. A6 Avant (C6) Armrest removal
    Mar 2010
    St Albans UK
    I am trying to find out how to remove some or all of the centre armrest assembly. I actually just want some way to attach a bracket to the back of it, on which I will mount a detachable TV screen. Can't believe there is no Haynes manual for this car!
    Southern County Softy
    20 Post(s)
    Not sure if the A6 is the same as my A4. Remove rear ashtray to get to the bolt holding the armrest. HTH
    Sent from my GT-I9100 using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: A6 Avant (C6) Armrest removal
    You need a hooked tool to pull out the rear ait vent then you can access the bolt and connectors. Bolt is 25 Nm on refitting. Regards Peter
  4. Re: A6 Avant (C6) Armrest removal
    Mar 2010
    St Albans UK
    Thanks Peter, any idea which part of the air vent to pull first? I presume then, that the bolt will be at the top of the opening, screwed up into the armrest?
  5. Re: A6 Avant (C6) Armrest removal
    Post up your email address or PM the address and I'll send you the drawing. Regards Peter
  6. Re: A6 Avant (C6) Armrest removal
    Mar 2010
    St Albans UK
    Peter, Thank you so much. very clear now.
  7. Re: A6 Avant (C6) Armrest removal
    Mar 2010
    St Albans UK
    These images show the round ended slots top and bottom where your hook needs to engage for pulling the vent out. If you pull out by the centre part of the vent like I did, you'll spend the next hour figuring out how it all goes back together (if you don't lose any bits)! If you can't see the photo's, right click and "open link in new window" or similar command.
    Feb 2012
    Stockholm, Sweden
    Ricktherazor,
    would you mind trying to post those photos again? I can't access them it seems. Would really appreciate it. I don't want to risk breaking the vents into pieces
    Feb 2012
    Stockholm, Sweden
    Nerver mind, I got it MIT was easy. Just pulling (forcing) out the back part of the side panels on the side of the armrest and then putting my fingers in there and pressing the vent until it popped out.
  1. Question Front armrest - where can i get one? - merged with Retro Fit Armrest thread
    By winnie070383 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-07-2011, 10:01 PM
  2. Avant rearlight removal
    By mikeybutch in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-05-2011, 08:06 AM
  3. Removal or area under center front armrest
    By spottedhaggis in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-09-2010, 08:32 PM
  4. Cup Holder on front of front armrest removal
    By Guest 2 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-03-2010, 09:18 PM
  5. Removal of armrest CD auto-changer
    By xerian in forum Beetle 2000-
    Last Post: 28-04-2008, 08:37 AM
