Thread: Blinking red LED on lights switch
Results 1 to 10 of 12
  1. Lightbulb Blinking red LED on lights switch
    Aug 2010
    Prishtina
    Last night as I was approaching my car I noticed a small red led blinking on my car's light switch. The blinking was not periodical (irregular) and continued that way even after unlocking the doors. When I started the car it stopped.
    I am attaching a picture to visualize about which led I'm talking.
    I tried looking on car's manual but no info on this indicator there. When looking on Google someone replied that it happened to him too on a very cold weather.
    Though it is very cold these days (-10 C) I doubt that small light has anything to do with temperature.
    Cad model: Audi B7 2005 TDI 2.0 140 Avant
    Any idea?
  2. Re: Blinking red LED on lights switch
    Feb 2012
    That is strange! Does it blink together with the alarm armed LED in the door if you have one?
  3. Re: Blinking red LED on lights switch
    Yateley, Hampshire
    It should be on when the lights are on. Mine went completely and I got Audi to replace it as you have to replace the whole unit and not just a bulb. What a surprise.
  4. Re: Blinking red LED on lights switch
    Jul 2010
    Bracknell
    The light is faulty. Mine started doing it aswell and would flash for a few moments and then come on irregularly over the next 10 seconds or so and then stay off.
    2006 Audi A3 2.0 TFSI Quattro S-Line Special Edition
  5. Re: Blinking red LED on lights switch
    Aug 2010
    Prishtina
    I definetly think it is not related to alarm led. It blinks indipendently from door alarm led.
    I was confused as it was blinking when door was locked and alarm enabled. Do you think the LED is on at all times no matter if car is on or off & door locked with alarm on?
  6. Re: Blinking red LED on lights switch
    Yateley, Hampshire
    Quote Originally Posted by vsheremeti View Post
    No it is just on when lights are on. Nothing to do with anything else. As I pointed out you will have to replace the complete unit.
  7. Re: Blinking red LED on lights switch
    Feb 2012
    That happened on my TT. Had to have the whole switch replaced but luckliy it was under warranty. I think they cost around £60 but you may strike lucky on ebay.
  8. Re: Blinking red LED on lights switch
    warp_speed Guest
    Here is the link in how to fix this, save yourself some money provided you can solder https://www.vwaudiforum.co.uk/forum/s...h-illumination
  9. Re: Blinking red LED on lights switch
    Feb 2012
    Great link, thanks for posting it. Was the problem simply down to a failed LED? Those hardly ever fail!
  10. Re: Blinking red LED on lights switch
    warp_speed Guest
    Quote Originally Posted by Akshay View Post
    Actually it might not be a failed LED, it might be a dry joint. Try re-soldering the joint and see if the light goes back on. Otherwise it might just be a bad LED, hard to believe but they can fail.
  1. Anyone fitted FK AUDI A3 8P 3 DOOR 03-05 RED/CLEAR LED TAIL LIGHTS???
    By rosso rocket in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-09-2011, 06:23 PM
  2. headlamp, red leds, hazard switch lights turn off after 5 seconds
    By patmcnamara78 in forum Golf MK5 - 2004 - 2009
    Last Post: 27-11-2010, 09:52 AM
  3. Question Alarm Indicator LED stays on for 30 seconds before blinking
    By BlackSmoke in forum Golf MK5 - 2004 - 2009
    Last Post: 17-04-2010, 11:56 AM
  4. 2005 TT Indicator lights not blinking
    By mikelikesaudi in forum TT - 8N Forum - 1998 - 2006
    Last Post: 07-02-2009, 07:15 PM
  5. Indicator Lights on STEADY iso BLINKING!
    By Peoplemover in forum Polo - Derby - Lupo - Fox
    Last Post: 05-03-2008, 12:36 AM
