Thread: Replacing dash clock
  1. Replacing dash clock
    Jan 2011
    Lancashire
    Hi all
    Would it be possible to replace the dash clock from my A6 for another from the same range or are the clocks linked via the ECU thus meaning the engine wont start?
  2. Re: Replacing dash clock
    Ayrshire, Scotland
    18 Post(s)
    Affraid the Imobiliser is coded to the dash and so it would not work unless you ask for the replacement to be coded to the car, why do you want to change it?
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Replacing dash clock
    Jan 2011
    Lancashire
    Quote Originally Posted by bagpipingandy View Post
    Andy
    I tried to replace the LCD screen and have managed to damage the printed circuit board.My only option now is to replace the clocks.
    Would I be right in thinking that any VAG dealer could reprogram the replacement clocks?
  4. Re: Replacing dash clock
    Ayrshire, Scotland
    18 Post(s)
    Yes they should be able to do it, check 1st with a dealer before buying any 2nd hand unit, assuming you are not buying a new one.
  5. Re: Replacing dash clock
    Feb 2007
    Cheshire
    My 2000 A6 Avant 2.4 had problems with the lcd screen for several years. I tried all the usual remedies like buying a 'how to do it cd' off ebay for £5 and took the whole unit out many times. Spent months trying to track down someone who could repair it and eventually sent it off for repair at a very well known repairers !!. They said it couldn't be repaired and personally, I think it ended up that way whilst it was there. I had to ask specifically for it to be returned as well. In the end I had to bite the bullet and buy a new one from Audi. These clocks are very model specific and each has a unique Part No. depending on the vehicle spec. By the time that I had it put in, coded in and with the mileage corrected etc. I was so glad to have it sorted that it helped me to forget about the cost. Sadly approx. £750 + !!! However, have never regretted it as I was just thrilled to bits to get the lcd back.
  6. Re: Replacing dash clock
    Dec 2011
    Southsea, United Kingdom
    you can buy a tool called: vag commander, there are clones available on ebay (whether you agree with that or not is beyond the scope of your question, i'm merely mentioning it to you) you can, with this tool, read, write and program immobiliser data into your new clocks. All you have to do is find a set of clocks with the same model number) you'll then be able to fit said clocks, code it to your car, write the immobiliser data and match it to your keys then write the mileage to the dashboard. You'll be done and finished in about 4-5hours all in and MUCH cheaper than the dealer.
  1. dash clock
    By raymondbilko in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 19-04-2013, 02:40 PM
  2. Attention !984 jetta dash cluster with clock
    By collinscw in forum Golf MK1 - 1974 -1984
    Last Post: 21-06-2010, 02:49 PM
  3. replacing dash panel
    By dryerman in forum Golf MK4 - 1999 - 2004
    Last Post: 11-02-2010, 06:31 PM
  4. How To Replacing clock spring on airbag.
    By emmbeedee in forum Alhambra
    Last Post: 17-11-2009, 05:57 PM
  5. Replacing centre dash vents
    By Solari in forum Golf MK4 - 1999 - 2004
    Last Post: 02-07-2008, 11:55 AM
