Thread: Which replacement battery for 04 '53 plate 1.9 Tdi 2.0 Touran pls ?
  1. Question Which replacement battery for 04 '53 plate 1.9 Tdi 2.0 Touran pls ?
    Jan 2010
    U.K
    It's getting obvious that the original car battery is on it's last leg and needs replacement but I'm a bit confused which replacement I should get.
    Currently has a Varta 12v battery, 280mm x 175mm, 70ah, 340A DIN.
    Other things on the label are IJO 915 10 5 AE, if that helps
    Halfords seem to be a no go as they only have wider batteries and they seem to the wrong voltage.
    Seen Varta batteries on other websites much cheaper and was hoping someone might know if I need an E38, E44 or something else ?
    Any advice ?
    Denise
  2. Re: Which replacement battery for 04 '53 plate 1.9 Tdi 2.0 Touran pls ?
    May 2010
    Devon England
    Varta Batteries are good TBH but if it was me id fit a bosch battery, when you say you need a new battery is it going flat or cranking over slowly? being a Varta in your car at the moment i would have thought it has been replaced at some point
  3. Re: Which replacement battery for 04 '53 plate 1.9 Tdi 2.0 Touran pls ?
    Jan 2010
    U.K
    Hi Phil
    I've had the car since it was about 9 months old from the dealer so hadn't thought it would have been replaced. Always a possibility though..
    It cranks over really slowly and has got more noticeably over the last few weeks.
    Denise
  4. Re: Which replacement battery for 04 '53 plate 1.9 Tdi 2.0 Touran pls ?
    May 2010
    Devon England
    ok, it does sound like the battery is on its way out, does it start ok when its hot, or does it crank over for ages before it starts? the 1.9 in tourans and golf mk5s suffer from slow starting when hot and its normally down to the starter motor drawing to much current
  5. Re: Which replacement battery for 04 '53 plate 1.9 Tdi 2.0 Touran pls ?
    Aug 2008
    Flitwick, Beds
    Just fitted a bosch to our Sharan. Old one was the original, not bad fo a 52plate eh? We got ours from Costco, £70 compared to about £120 from Halfords for the same one. Costco book says a much bigger battery though, the one we got was same as original size and still higher output, 75 amph instead of 70.
    So I'd suggest getting to your nearest costco.
  1. charging the battery in my touran 2.0 TDi
    By eddie3625 in forum Touran - Sharan - Caravelle
    Last Post: 03-02-2012, 09:48 PM
  2. Please Help touran 04 plate 2.0 pd tdi sport
    By k31tha in forum Touran - Sharan - Caravelle
    Last Post: 28-05-2011, 11:13 PM
  3. Battery replacement 1.9 tdi
    By David1953 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-12-2010, 09:58 PM
  4. Flat battery on GT Tdi 140 (55 plate)
    By missilemary in forum Golf MK5 - 2004 - 2009
    Last Post: 23-07-2010, 07:52 AM
  5. Golf GT TDI Mark 5 54 PLate - Battery Drain!?!?!
    By thaidai in forum Archive posts
    Last Post: 17-01-2008, 01:08 PM
