Thread: 1.4 tsi boost problems limp mode
  1. 1.4 tsi boost problems limp mode
    Aug 2008
    i have a 200 golf gt 1.4 tsi (supercharger & turbo), its causing some problems, it started with these fault codes
    Address 01: Engine Labels: 03C-906-032-BLG.lbl
    Control Module Part Number: 03C 906 032 A HW: 03C 906 032
    Component and/or Version: MED17.5.1 9971
    Software Coding: 0000072
    Work Shop Code: WSC 00442 210 91419
    VCID: 1B3E003BA33E
    2 Faults Found:
    008801 - Boost Pressure Control Valve (N249): Mechanical Malfunction
    P2261 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 58824 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:04:25
    Freeze Frame:
    RPM: 2590 /min
    Load: 26.7 %
    Speed: 61.0 km/h
    Temperature: 85.0°C
    Temperature: 16.0°C
    Absolute Pres.: 970.0 mbar
    Voltage: 13.970 V
    004261 - Position Sensor for Intake Air Regulating Flap: Signal too High
    P10A5 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 58824 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 16:04:21
    Freeze Frame:
    RPM: 2737 /min
    Load: 90.6 %
    Speed: 53.0 km/h
    Temperature: 85.0°C
    Temperature: 18.0°C
    Voltage: 13.589 V
    i have cleared the boost pressure control valve (n249) fault by changing the valve on the turbo (part number 03c 145 710 d)
    i am now left with just this
    VCID: 1B3E003BDABEE1B
    1 Fault Found:
    P10A5 - 000 - Signal too High - MIL ON
    Freeze Frame:
    Fault Status: 11100000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 58883 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 15:20:00
    Freeze Frame:
    RPM: 2672 /min
    Load: 61.5 %
    Speed: 52.0 km/h
    Temperature: 85.0°C
    Temperature: 10.0°C
    Absolute Pres.: 990.0 mb
    also when driving hard i have noticed that the boost gauge will go to full boost until the revs reach about 3500rpm then they drop back to only half boost for the rest of the rev range. when back below 3000rpm the boost goes back to full.
    please does any one have any ideas ?????
    thanks in advance
  2. Re: 1.4 tsi boost problems limp mode
    Sep 2009
    England
    Did you get any where with this? My suggestion would be to replace N75
  3. Re: 1.4 tsi boost problems limp mode
    Aug 2008
    I have now tried, pcv, n75, and the Flap with the position sensor fault (sorry can't remember the name, the silver one towards the rear of the engine). Still getting problems. Think it's time to start looking at turbo and charger now.
    Do you have similar problem??
  4. Re: 1.4 tsi boost problems limp mode
    Sep 2009
    England
    Can that fault be erased? or is it permantly logged?
  5. Re: 1.4 tsi boost problems limp mode
    Aug 2008
    Sometimes not but mostly can be erased
  6. Re: 1.4 tsi boost problems limp mode
    Sep 2009
    England
    Will have a think about this one. 'Signal too high' can sometimes mean a poor connection in wiring. Not saying it is definatly that, but had a 'boost pressure sensor, signal too high' fault on a scirocco and it was partially broken wiring at the connector. Worth checking the wiring out.
  1. Please Help Limp mode loss of turbo boost
    By dan2134 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2011, 03:11 PM
  2. Please Help Coil Pack issues and limp mode problems.
    By Zeb in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-06-2010, 11:27 AM
  3. 1.9TDI Quattro Boost Cutting out then Limp Mode
    By rallyman in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 21-07-2009, 08:31 PM
  4. Please Help boost cutting out and limp mode
    By 90karl90 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-05-2009, 06:18 PM
  5. A4 Avant limp mode problems
    By mantec in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-07-2007, 11:11 PM
