Thread: Audi A4 oil pump / balancer shaft
  1. Audi A4 oil pump / balancer shaft
    Jan 2012
    Ipswich, Suffolk
    I know I am not on my own but I am seriously dissapointed in Audi as a dealership now - '08 plate 2lt Audi A4, 40,000 miles, full service history and my wife breaks down on 5th January.
    Fault was diagnosed as oil pump failed which has a modified balancer shaft which is such a design change - i.e. a recognised fault, that a new sump needs to be fitted too.
    Major supplier issue and part not available with an undefined delivery date so vehicle off the road. Contacted HQ "customer service team" who will not acknowldge a problem but will loan me a car whislt my wifes is off the road BUT they need the car and their charge is at least £800 more than my quote. The parts alone are circa £1500 plus circa 10 hours labour - only 8 months out of warrenty and plenty of A4's & 6's with this issue.
    Retorical rant really as the only ones who can change my situation is Audi and the ycouldn't give a stuff so I am now letting as many people know about tehir lack of care and try to put people off buying them where ever possible.
  2. Re: Audi A4 oil pump / balancer shaft
    and no better place to start than a forum full of VAG fans, right?
    an unwise move due to several factors.
    You posted your thread in the wrong section
    You've created a rather silly username
    You've included several spelling and grammar errors in your post.
    I sympathise with people who buy lemons, honestly I do.
    FWIW - 8 months out of warranty is quite a decent length - you wouldn't take a faulty washer back to Currys 8 months after it's warranty expired and expect them to fix it FOC would you?
  3. Re: Audi A4 oil pump / balancer shaft
    Dec 2009
    southampton uk
    If I was in his shoes I would feel the same and its understanderable to lash out a bit without worrying about marks for presentation.A major fault like this must raise the question of was the car fit for purpose and there seems to be a case for some redress.I have heard of similar cases suceeding and would think about a claim in the Small Claims Court
  4. Re: Audi A4 oil pump / balancer shaft
    We don't know if the vehicle is used or has been maintained from new, which would cast doubt on the fit for use argument.
    We also don't know if Audi UK have offered any goodwill on the work.
    Taking Audi UK to the small claims court, I fear, is not the best course of action for anybody to consider.
    I believe Crasher has a fair bit of experience with this particular fault so can probably advise more accurately on the best plan of attack.
    A point I will make as an aside is that people tend to forget that expensive cars tend to be expensive to fix when they go wrong. Cars do go wrong, they're machines - even Audi can't promise 100% reliability.
  5. Re: Audi A4 oil pump / balancer shaft
    Dec 2009
    southampton uk
    He says its got full history Audi I assume and has done just 40k.Surely there a case to answer.Action in the SCC is a straight forward way to get results
  6. Re: Audi A4 oil pump / balancer shaft
    to take the matter to SCC, there would need to be a breach of rights and/or a contract? The vehicle is out of warranty by 8 months.
    whilst I agree it sucks, they're the facts.
    best you can hope for is goodwill from Audi, taking them to SCC (should it be accepted as a claim) will not serve to aid that.
  1. Balancer Shaft Query
    By coolraj003 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-09-2012, 06:55 PM
  2. Balancer Shaft Problems ?
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-09-2012, 08:24 AM
  3. Reconditioned balance shaft & oil pump
    By kunaalv in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 24-07-2012, 04:10 PM
  4. Oil pump balancer shaft
    By mission66 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-08-2010, 08:10 AM
  5. 2.0 TDI Oil Pump Balance Shaft Problems
    By Jack Ford in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-01-2010, 11:39 AM
