Thread: Glow plug light flashing
Results 1 to 9 of 9
  1. Glow plug light flashing
    Sep 2008
    Hi All,
    I had the flashing glow plug light come on yesterday (Engine management system warning), and a full scan is shown below. Car starts but hesitates for a few seconds before it fires up.
    I have a 2004 Audi A8 3.0 TDI Quattro (4E D3) model. The car had been left on the drive for about 4 weeks as I had wait for replacement tyres to be delivered and fitted. As a result I am not too concerned about the battery regulator faults as I think they are related to the battery being drained over those 4 weeks.
    However I am wanting to resolve the Glow plug fault and wanted to know if the scan below is definative indication of faulty glow plug or if I should investigate further before booking it in for replacement glow plugs. I am fairly competent at DIY and service the car etc.. but the access for the glow plugs is tight and therefore a little reluctent to start messing around with this
    Any ideas on likely costs for getting the 6 glow plugs replaced and the EGR valve cleaned?
    Any help/thoughts appreciated.
    thanks in advance.
    Chassis Type: 4E0
    Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 1E 25 34 36 37 38 42
    46 47 4F 52 53 56 57 61 62 72 76 77
    VIN: WAUZZZ4E14N025387 Mileage: 113110km/70283miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: Malfunction 0010
    06-Seat Mem. Pass -- Status: OK 0000
    07-Control Head -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    18-Aux. Heat -- Status: Malfunction 0010
    1E-Media Player 2 -- Status: OK 0000
    25-Immobilizer -- Status: Malfunction 0010
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    37-Navigation -- Status: OK 0000
    38-Roof Electronics -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    57-TV Tuner -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    76-Park Assist -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 4E0 910 401 H HW: 4E0 907 401 B
    Component: 3.0L V6TDI G000AG 0050
    Revision: --H01--- Serial number: AUX3Z0D3140167
    Coding: 0011773
    Shop #: WSC 00052 210 88667
    VCID: 204435A0F3D8C23
    1 Fault Found:
    17055 - Cylinder 1 Glow Plug Circuit (Q10)
    P0671 - 001 - Electrical Fault - MIL ON
    Freeze Frame:
    RPM: 0 /min
    Torque: 280.8 Nm
    Speed: 0.0 km/h
    Duty Cycle: 1.0 %
    Voltage: 11.10 V
    Duty Cycle: 33.9 %
    Temperature: 4.5°C
    Bin. Bits: 00110000
    Readiness: 0 0 1 1 1
    Address 02: Auto Trans Labels: 09L-927-760.lbl
    Part No SW: 4E0 910 156 F HW: 09L 927 156
    Component: AG6 09L 3.0lTDI RdW 0050
    Revision: 00000001 Serial number: 0016668
    Coding: 0000001
    Shop #: WSC 02313 785 00200
    VCID: 254A24B4ECFA27B
    No fault code found.
    Address 03: ABS Brakes Labels: 4E0-910-517.lbl
    Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
    Component: ESP 5.7 allrad H44 0500
    Coding: 0008357
    Shop #: WSC 02313 000 00000
    VCID: 22403FA8FDD4D03
    Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
    Part No SW: 4E0 910 131 HW: 4E0 909 131
    Component: FBS AUDID3 H03 0140
    Revision: 01403903 Serial number: AUX3Z0D3140167
    Coding: 0264192
    Shop #: WSC 02311 785 00200
    VCID: D8B4DD406B08CA3
    Part No: XXXXXXXXXXX
    Component: ELV XXXX
    1 Fault Found:
    00668 - Supply Voltage Terminal 30
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 113104 km
    Time Indication: 0
    Date: 2012.01.28
    Time: 21:13:50
    Address 06: Seat Mem. Pass Labels: None
    Part No SW: 4E0 910 760 C HW: 4E0 959 760
    Component: Sitzmemory BFS H08 0060
    Revision: 00000000 Serial number: 5DS 008 795-03
    Coding: 3670112
    Shop #: WSC 00000 785 00200
    VCID: 234E3AACE2CED9B
    Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
    Part No SW: 4E0 910 732 A HW: 4E0 035 729 A
    Component: Interfacebox H43 4220
    Revision: 00000000 Serial number: 300DE047535119
    Coding: 0000002
    Part No: 4E0 910 609 A
    Component: Bedienteil MMI H42 0020
    Address 08: Auto HVAC Labels: None
    Part No SW: 4E0 910 043 A HW: 4E0 820 043 A
    Component: KLIMAAUTOMAT 016 0300
    Revision: 00000025 Serial number: 00000000042318
    Coding: 1067009
    VCID: 1B3E024CDABEE1B
    Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
    Part No SW: 4E0 910 279 J HW: 4E0 907 279 J
    Component: ILM Fahrer H12 0190
    Coding: 0100001
    VCID: 2F66C69CBE066DB
    Subsystem 1 - Part No: 4E2 910 113 B
    Component: Wischer WWS D3 H50 0420
    Coding: 00000000
    Shop #: WSC 02313
    Address 15: Airbags Labels: 4E0-910-655-84.lbl
    Part No SW: 4E0 910 655 HW: 4E0 959 655 G
    Component: Airbag 8.4E+ H10 0940
    Coding: 0431707
    VCID: E3CEFAAC224E19B
    Address 16: Steering wheel Labels: 4E0-910-549.lbl
    Part No SW: 4E0 910 549 HW: 4E0 953 549
    Component: Lenksäulenmodul H13 0040
    Coding: 0112041
    VCID: E5CAE4B42C7A67B
    Component: Lenkradmodul H04 0080
    Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
    Part No SW: 4E0 910 900 HW: 4E0 920 950 A
    Component: KOMBIINSTR. VDO H44 0090
    Revision: D15 Serial number: AUDID3D3001478
    Coding: 0000403
    Shop #: WSC 80093 222 69422
    VCID: DCBCC1501F30263
    Address 18: Aux. Heat Labels: None
    Part No SW: 4E0 910 105 HW: 4E0 815 069 D
    Component: Heizgeraet H06 0300
    Revision: 0000000G Serial number: 00000009001484
    Shop #: WSC 00000 000 00000
    VCID: D9B2D8441002D3B
    1 Fault Found:
    02251 - Heater Unit Locked
    000 - -
    Address 19: CAN Gateway Labels: 4E0-910-468.lbl
    Part No SW: 4E0 910 468 HW: 4E0 907 468 A
    Component: Gateway H07 0070
    Revision: 07 Serial number: 1600304326053D
    Coding: FCFE5BDE2B3504
    Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
    Part No SW: 4E0 910 111 F HW: 4E0 035 111
    Component: CD-Changer H44 0470
    Revision: 00000000 Serial number: AUZ5ZBD4022223
    VCID: 1C3C0150DFB0E63
    Address 25: Immobilizer Labels: 4E0-910-131.lbl
    Coding: 0264192
    Component: ELV XXXX
    XXXXXXXXXXX ELV XXXX
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 164
    Mileage: 113104 km
    Time Indication: 0
    Date: 2012.01.28
    Time: 21:13:50
    Address 34: Level Control Labels: 4E0-910-553.lbl
    Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
    Component: LUFTFDR.-CDC H05 4290
    Coding: 0015510
    Address 36: Seat Mem. Drvr Labels: None
    Component: Sitzmemory FS H08 0060
    Coding: 3670114
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 887 T HW: 4E0 919 887 C
    Component: MNS ECE H43 1030
    Revision: 00000000 Serial number: 353DL047514247
    VCID: 3E78EBD8696C943
    Address 38: Roof Electronics Labels: 4E0-910-135.lbl
    Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
    Component: Dachknoten D3 H01 0090
    Serial number: 00000409800047
    Coding: 0035968
    VCID: 1D3A0C54C4AAEFB
    Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
    Part No SW: 4E1 910 802 HW: 4E2 959 802
    Component: Türsteuer.FS BRM007 0110
    Coding: 0028462
    VCID: DEB8CB58092C343
    Address 46: Central Conv. Labels: 4E0-910-289.lbl
    Part No SW: 4E0 910 289 A HW: 4E0 907 289
    Component: Komfortgeraet H04 0040
    Revision: 00400004 Serial number: W040404210067
    Coding: 0005373
    Shop #: WSC 00052 210 83205
    VCID: 27562EBC96F635B
    Part No: 4E0 910 853
    Component: Heckdeckel P14H06 0070
    Part No: 4E0 907 719
    Component: Neigungssensor H03 0020
    Address 47: Sound System Labels: 4E0-910-223.lbl
    Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
    Component: DSP-Amp.-High H13 0440
    Revision: PROD_01 Serial number: 00000000001371
    Coding: 0000013
    Address 4F: Centr. Electr. II Labels: None
    Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
    Component: ILM Beifahrer H09 0040
    Revision: Serial number: 00000000038965
    Coding: 0010001
    VCID: 1E380B58C9ACF43
    Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
    Part No SW: 4E1 910 802 HW: 4E2 959 801
    Component: Türsteuer.BF BRM007 0110
    Coding: 0028462
    Address 53: Parking Brake Labels: 4E0-910-801.clb
    Part No SW: 4E0 910 801 A HW: 4E0 907 801
    Component: EPB AV1C1010 H01 1010
    Revision: AV1C1010
    Coding: 0000221
    Shop #: WSC 00958 210 12835
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 Q HW: 4E0 035 541 B
    Component: TUNER EU/US/RDW H41 0620
    Revision: 00000000 Serial number: 304DV047586657
    Coding: 0000001
    VCID: 2E58DB98B90C643
    Address 57: TV Tuner Labels: 4E0-910-146.lbl
    Part No SW: 4E0 910 146 G HW: 4E0 919 146
    Component: TV analog TUNER H12 0300
    Revision: 00000063 Serial number: 00000000002032
    Coding: 0001003
    Address 61: Battery Regul. Labels: 4E0-910-181.lbl
    Part No SW: 4E0 910 181 B HW: 4E0 915 181
    Component: ENERGIEMANAGER H02 0240
    Revision: 00000000 Serial number: 00000002031636
    Shop #: WSC 00509 210 14479
    VCID: 1F46365CCEA6FDB
    Subsystem 1 - Part No: 000 915 105 AK
    Component: von VA0 2403290271
    Coding: 303030393135313035414B56413032343033323930323731
    Shop #: WSC 00000 128 00289
    3 Faults Found:
    02272 - Quiescent Current Stage 1
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 2
    Mileage: 113119 km
    Time Indication: 0
    Date: 2012.01.28
    Time: 21:18:14
    02273 - Quiescent Current Stage 2
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 113119 km
    Time Indication: 0
    Date: 2012.01.28
    Time: 21:21:24
    02276 - Quiescent Current Stage 5
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Mileage: 113119 km
    Time Indication: 0
    Date: 2012.01.28
    Time: 21:21:35
    Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 HW: 4E0 959 801 A
    Component: Türsteuer.HL BRM007 0110
    Coding: 0028462
    VCID: DDBACC54042A2FB
    Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
    Part No SW: 4E0 910 802 HW: 4E0 959 802 A
    Component: Türsteuer.HR BRM007 0110
    Coding: 0028462
    Address 76: Park Assist Labels: 4E0-910-283.lbl
    Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
    Component: Parkhilfe 8-Kan H12 0020
    Revision: --.--.-- Serial number: 08730410705093
    Coding: 0001008
    VCID: 214230A4F8D2CBB
    Address 77: Telephone Labels: 4E0-910-333.lbl
    Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
    Component: TELEFONMODUL EU 0770
    Revision: 00000006 Serial number: T2AUD31011HC7W
    Coding: 0000004
  2. Re: Glow plug light flashing
    Jun 2006
    UK, Mids
    If you clear the fault, does it return?
    A low battery can cause all sorts of codes to appear in various modules, so could be a red herring.
    If it is a glow-plug, it isn't necessary on these engines for starting, even in winter, they are more for reducing emissions and post-start noise.
    Think carefully before changing one, as the risks of it stripping the threads or snapping off may make it worth not bothering.
    Plus-gas them for a week or two before hand and invest in good quality glow-plug socket.
    Audi A8 - 2015 - 3.0TDI
    1 1 0
  3. Re: Glow plug light flashing
    Sep 2008
    Hi Snapdragon,
    Thanks for your reply.
    I cleared the fault codes and the glow light (flashing) and fault code returns as soon as I try to start the car. Sorry if this sound silly but when you say try "gas them..." what are you referring too?
    I drove the car around (before the issue came to light) to allow the battery to charge up (got it to 100% on the MMI meter). however do you think before I do anything else I should simply trickle charge the battery using a charger to ensure a proper charge then try and scan again? Also Do you think it is safe to drive with the above or could this cause further damage?
    thanks again appreciate you taking the time to reply.
    Happydan.
  4. Re: Glow plug light flashing
    Jun 2006
    UK, Mids
    Plus-gas is a make of penetrating fluid who's name has gained generic usage, a bit like WD40.
    http://www.amazon.co.uk/s/?ie=UTF8&k...l_1qcsczwdic_e
    It does sound like glow plug or glow plug circuit as the fault comes back.
    I wouldn't worry to much about the battery if it is holding charge.
    You can trickle charge it if you like, but use the charging point above the battery for the -ve connector.
    Not having a working glow plug is unlikely to do damage. If you can get to the one you suspect you can test it with a multimeter or test lamp in situ.
    It does sound as though you will have to get it done to stop the warning light (which could also mask another fault if it is already flashing)
    Good luck.
  5. Re: Glow plug light flashing
    Sep 2008
    Thanks Snapdragon,
    I appreciate your feedback on the post. I think I will book it in to a reputable garage that knows the Audi's and get the glow plugs replaced. Will probably get the full set replaced while they are doing them and maybe the EGR valve cleaned out as well given I have just hit 70k miles and I have heard that this is a job that needs doing around this many miles for good maintainence.
    Will post back on here as soon to update everyone as to how I got on.
    thanks
    Happydan.
  6. Re: Glow plug light flashing
    Sep 2008
    Hi all,
    Just a quick update I took the car to AMD in Thurrock and they replaced all 6 Glow plugs and cleaned out the EGR valve for me and the car looks like it is all good again on that front now. Only a couple of minor items o/s which are to replace the battery & the check the parking sensors now which dont work every now and then so sounds like a loose connection on one of the sensors - after these 2 jobs get done the car should be sweet once more.
    thanks to all those that have helped on this forum so far on questions.
  7. Re: Glow plug light flashing
    Sep 2008
    Managed to get some pics of the old glow plugs - not sure which one was the faulty one but thought this might interest someone.
    1 1 0
  8. Re: Glow plug light flashing
    Jun 2006
    UK, Mids
    Nice one spiderman, what make are the original ones?
  9. Re: Glow plug light flashing
    Sep 2008
    Originals were "BERU" and replaced with exact same make so hopefully keep the big beast happy!!
    1 1 0
  1. Please Help Glow plug light flashing
    By sunshinekid in forum Octavia
    Last Post: 02-02-2010, 12:29 AM
  2. glow plug light flashing
    By rollingroadtune in forum Alhambra
    Last Post: 12-05-2009, 03:25 PM
  3. a3 flashing glow plug light
    By yalittlebeauty in forum Audi A3 - Archive Topics
    Last Post: 05-02-2009, 10:57 AM
  4. flashing glow plug light !help!
    By Bora Boy in forum Archive posts
    Last Post: 09-12-2007, 12:11 PM
  5. flashing glow plug light
    By imanutter in forum The Commercial Range
    Last Post: 02-12-2007, 07:12 PM
