Thread: A6 Allroad rear brake caliper wind back URGENT HELP!!!!
  1. A6 Allroad rear brake caliper wind back URGENT HELP!!!!
    Aug 2007
    Asnières-sur-Blour, Vienne, France
    9 Post(s)
    Hello,
    On my 2006 A6 Allroad 3.0 tdi, I decided to change the rear discs and pads today but I cannot get the pistons to wind back.
    For years I have used a tool I made which I made from a core plug with two spots of weld inside and welded a shaft onto it so I just put it in my cordless drill offered it up and it wound back the calipers on several Audis and VWs over a number of years.
    Now I find that there are three notches in the end of the piston instead of two and the diameter is about 39 mm instead of 37 mm. I have had to make a new tool modifying a ceramic tile hole cutter and it turns the end of the piston fine and I apply pressure as before but the piston refuses to go in.
    Is there something else I should do? This car has the electric handbrake and I suspect that the gubbins mounted on the back of the caliper has to do with that, has something else got to be disconnected before being able to rewind the piston?
    I have a long journey to do tomorrow and am reluctant to put the old pads and discs back on.
    I hope that someone can help me soon.
    Regards,
    Michael
  2. Re: A6 Allroad rear brake caliper wind back URGENT HELP!!!!
    f33nix Guest
  3. Re: A6 Allroad rear brake caliper wind back URGENT HELP!!!!
    Aug 2007
    9 Post(s)
    Thank you f33nix,
    I have not been able to find the post you mentioned, if you remember how you found it I would be grateful to know.
    Put it all back together with the old discs and pads for the next few days and will maybe have another go in a week or so, I hope I can find a bit more info before then.
    The discs I was supplied seem to be wrong anyway, laying them flat they have a maximum height of 50 mm but the ones on my car measure only about 42 mm and there is maybe less than 1 mm wear on the bottom side of the disc. When offered up they seem to foul the caliper support bracket. Disc diameter, thickness and holes are the same though.
    Regards,
    Michael
  4. Re: A6 Allroad rear brake caliper wind back URGENT HELP!!!!
    Mar 2009
    Helsingborg, Sweden
    Just seen this, is it any help ........ http://forums.audiworld.com/showthre...92&ref=esp-img
    2012 VW CC 2.0 TDi
  1. Please Help Can't wind back rear piston urgent
    By Dustcap in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-09-2010, 01:29 PM
  2. Sealey Brake Caliper Wind Back Tool
    By Zedrider in forum Chat - Completely Off Topic
    Last Post: 03-12-2009, 11:57 PM
  3. Question rear brake caliper wont wind in
    By stan still in forum Golf MK4 - 1999 - 2004
    Last Post: 10-05-2009, 02:11 AM
  4. Question Caliper wind back tool !
    By Dazzler01 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-04-2009, 11:50 AM
  5. Brake Caliper Wind Back Tool
    By Walesgbn in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 20-09-2008, 11:08 AM
