Thread: Rough Idle / Difficult cold start
  1. Rough Idle / Difficult cold start
    Apr 2009
    Mansfield
    Hi All
    Anyone help. My Mrs took her A4 Cab 1.8T to Halfords (I know!!)the other morning when she was stuck with noisy steering, after I'd already gone to work. They checked and repaired a faulty PS pump pipe. (£100!!!!) That'll teach me to not be around! Anyway since then the cars been struggling to start / idle after a cold start in the morning. After warming up it's fine for the rest of the day. Is this coincidence or has a sensor (CO2?) been caught during the repair. I don't know what's in the region of the PS pump.
    MArk
  2. Re: Rough Idle / Difficult cold start
    May 2008
    darlington
    get the fault codes read, it could be many things.
  3. Re: Rough Idle / Difficult cold start
    Jun 2006
    Cardiff
    Coolant temp sensor would be my guess, especially if it's ok when up to normal temp. Possible that Halfords have disturbed the CTS connector, but more likely the CTS is faulty & it's just coincidence that it's failed at the same time as having the PS pump replaced.
    CTS has 2 outputs 1 to the temp gauge & the other to the ECU. It's very common for 1 output to be working correctly while the other isn't. If the ECU thinks the engine is hot when it's actually cold it won't fuel correctly hence the poor idle & cold start issue. VAG revised the CTS as the old ones kept failing. Unfortunately CTS failure doesn't always throw a fault code. If it's gone open circuit or intermittent it will, but if the ECU is still getting a reading it won't throw a code.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  1. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  2. rough idle on start up
    By vwtdi130pd in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2010, 08:34 AM
  3. Rough idle when cold
    By mean318 in forum Early Passat Forum - Pre 97
    Last Post: 01-12-2009, 10:43 PM
  4. Please Help Rough idle, now doesn't start properly
    By AcidUK in forum Golf MK4 - 1999 - 2004
    Last Post: 30-12-2008, 10:12 PM
  5. 1996 Golf GTI difficult to start from cold
    By Torchie in forum Golf MK3 - 1993 - 1999
    Last Post: 30-01-2008, 07:11 PM
