Thread: Dipstick
Results 11 to 20 of 37
  1. Re: Dipstick
    131 Post(s)
    1978 Post(s)
    That is from the workshop system but there is now a newer version with date revisions.
  2. Re: Dipstick
    Dec 2013
    Ilford, London
    SOLUTION!!!!
    Just to let everyone know, I have an Audi A4 B8 2009 2.0TDI Engine, i have done my research just like everyone else about this annoying dipstick issue. My dipstick tube is located underneath engine cover with a plug.
    I found a solution at long last!!!!
    I purchased this dipstick which was perfectly correct for my vehicle on eBay- CLICK HERE
    Now I can always check my oil level on both MMI and manually finally.
  3. Re: Dipstick
    Apr 2012
    Aylesbury, Bucks
    Check out Laser Tools dipstick part no 4807. £13-15 approx.
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  4. Re: Dipstick
    Dec 2013
    Ilford, London
    Quote Originally Posted by power33 View Post
    Quote Originally Posted by rafletcher View Post
    I looked at the Laser Tools, but thought it wasn't good enough. Now my dipstick fits even under the engine cover just for when I need to use it lol
  5. Re: Dipstick
    Aberdeen
    63 Post(s)
    And the seller comes from the same area as you. Really handy, you can pop round and pick it up. What a stroke of luck.
  6. Re: Dipstick
    Jul 2015
    Warrington
    I bought a Laser 4807 dipstick today for my 2010 A4 B8 2.0 tdi quattro. It came with no instructions.
    The latest instructions on Laser website are different to those posted by Crasher.
    I have set it to 62mm as per instructions and it barely registers at the '0' level with oil.
    Anybody used one of these lately with a 2.0 tdi engine? Should I be using 46mm as the start mark?
  7. Re: Dipstick
    #17
    Apr 2014
    Ireland
    Quote Originally Posted by Slee1977 View Post
    Slee1977
    I bought mine from Sealey Audi Engine Dipstick 600mm VS600ED | eBay
    Set top aduster ring to 46mm and fill oil up to level 25mm on lower scale - (make sure stick is fully inserted ie the bevel face of adjustment ring is sitting right in the dipstick hole) my MMI always reads "oil level OK" for me at this level.
    As sanity before you remove oil - set adjuster to 46mm and Dip check to see where your current oil level is at on lower scale
  8. Re: Dipstick
    #18
    Jul 2015
    Warrington
    Thanks.
    It looks identical to the Laser version.
    I guess the most important aspect is the length of the dipstick and the distance from the bottom of it to your 46mm marker point isn't it?
    Sent from my SM-N9005 using Tapatalk
  9. Re: Dipstick
    #19
    Jul 2015
    Warrington
    Just for information in case anybody else is looking for a dipstick for their 2.0 tdi:
    It turns out the instructions at the time I downloaded them (and posted my previous message) were wrong
    After having trouble using the Lasertools 4807 dipstick, I contacted them and got this reply:
    "Thank you for your enquiry.
    The Laser 4807 dipstick is compatible with your Audi 2.0 TDI CR engine.
    The measurement to set the adjuster ring on the dipstick is 46mm.
    The maximum oil level on the bottom scale is 24mm.
    The minimum oil level on the bottom scale is 0mm
    Sorry for any inconvenience."
    I have now adjusted the setting and am getting a perfectly good reading.
    This also means that if you connect your car to VagCom/VCDS to get your oil level readings and they read about 78.500mm they are within the healthy range...
  10. Re: Dipstick
    #20
    Jun 2014
    folkestone,uk
    If you go on parts request on Audi sport and order item number 06J115611E it should fit,thats the one I ordered for my 2008 1.8tfsi and it fits perfect
  1. I have no dipstick!
    By Black Phantom in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 29-03-2015, 09:24 PM
  2. dipstick!
    By SebRogers in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-09-2011, 01:26 PM
  3. Dipstick.
    By DSG4ME in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 20-08-2010, 08:43 PM
  4. a6 dipstick
    By pw11 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-12-2009, 03:28 PM
  5. What a dipstick!!
    By jimgironde in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-07-2009, 09:57 PM
