Thread: A6 allroad all was well then......
Results 1 to 10 of 15
  1. A6 allroad all was well then......
    Jun 2011
    Coventry
    2006 allroad 3lt, all was ok, I fill up with diesel, i drive from forecourt to main car park of asda, i go shopping and im back in the car within 5 mins, off i go and radio stops for a second then comes back on, this does this on all stations and now wont let me play a cd so im ruling out signal issue, its as if the power is being turned on and off.
    So i think go home switch it all off and try again after ten mins, but now a further clue has presented itself, at the same intervals of loss of sound I notice the door/footwell lights (LED) go on and off?
    So any ideas chaps (&chapessess)?
    Im scared?!
    Matt
  2. Re: A6 allroad all was well then......
    Oct 2010
    Berkshire, UK
    In the boot, does the carpet and the area that holds the hifi equipment look wet? Also, is the passenger foot well wet at all?
    If not, you need to get the car scanned. It could be anything.
  3. Re: A6 allroad all was well then......
    Jun 2011
    Coventry
    Thanks for the reply Josh,
    I have just popped out in daylight to check, no dampness or wet in the boot, or in the compartment where the sat nav drive is, nor in the footwell, all carpets dry as well.
    How much is a plug in scan, do you think?
    Matt
  4. Re: A6 allroad all was well then......
    Oct 2010
    Berkshire, UK
    Couple of things then.
    Are you sure there is nothing in your glove box pressing on the CD Player? Try again after completely emptying your glovebox
    Can you press and access all of the functions on the MMI control panel? If not, have you spilt any liquid on the MMI?
    Are you confident that this is not a battery issue? Forget the MMI battery meter display, can you get a voltmeter across your battery and test the voltage with the engine off and then with it running?
    In terms of a scan, it worth asking members here if they could do it for you. If you were in Berkshire, I could scan you for free!
  5. Re: A6 allroad all was well then......
    Jun 2011
    Coventry
    Thanks again Josh, over the weekend I will get the battery checked MMI says its 100%. No drinks or moisture have been in cabin so MMI not wet/spilt over.Will check glove box contents.
    As far as other functions, Car set up works fine as does Sat Nav, but phone (I phone3) doesnt now register on MMI and also cd player doesnt work. Also last night door LED's flash in tandem with radio in/outage but this morning no flashing door lights?
    Where are you in berkshire our head office is in Wimbledon and Im there in a few weeks, might be worth me coming over to you?
    thanks again
    Matt
    PS will also repost asking of anyone in my area with scan facilities
  6. Re: A6 allroad all was well then......
    Oct 2010
    Berkshire, UK
    I am in Bracknell most days
  7. Re: A6 allroad all was well then......
    Oct 2010
    Berkshire, UK
    definitely seems like water damage to me. Have you looked int he plenum chamber under the bonnet where all the fuse box/relays are?
  8. Re: A6 allroad all was well then......
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by josha6 View Post
    i am in bracknell most days
    snap !!
    A4 2.5 tdi QS (mapped)
  9. Re: A6 allroad all was well then......
    Oct 2010
    Berkshire, UK
    we probably work for the same telecoms company then!
    20 Post(s)
    Not me.....
    using tapatalk from my phone
  1. Allroad into an a4
    By brownie 25 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 15-04-2010, 09:51 PM
  2. Hi everyone!! New A4 Allroad
    By 20av30 in forum New Member Introductions
    Last Post: 11-09-2009, 09:36 AM
  3. A4 allroad
    By onemanparty in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-06-2009, 10:34 AM
  4. A6 vs Allroad
    By A6_JAck in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-05-2009, 11:36 AM
  5. 2.7T Allroad
    By slickoneuk in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 15-06-2008, 09:08 PM
