Thread: Sticky door lock
  1. Sticky door lock
    Oct 2005
    Had problems with the passenger door lock a while back. Sometimes had to pull the handle twice before it would open, once would pull open onto secondary latch and again to release fully. started having to wack the door to get it to open at all after a while, so I got one from the scrapyard to replace.
    The second one has started with the same problem after a couple of months.
    I get the impression its a common problem so I think a shiny new one will have to be ordered, but do I get a wallet sapping VW one or a cheap Polish one of ebay?
    My part number is 25L.....3B2 837015L
    But the one advertised says 3B187015A
    It looks pritty much identical but Googleing it suggests that it's a skoda part and only compatible with Lefthand drives?
    Anyone tried these parts? will they work the same. I'm sure there is comonality over a lot of VWs and skodas, but need to be sure on this one.
    The cheap one is about £45 and I'm told the VW one will be at least twice that.
  2. Re: Sticky door lock
    Dec 2009
    southampton uk
    My Bora was doing this so I sprayed some contact cleaner inside and its been OK since
  3. Re: Sticky door lock
    Dec 2007
    Belfast
    Hi.
    I had a problem with my door lock which meant it had to be replaced.
    Got the replacement one from VW for £80 and got my autospark to fit for £30.
    Never thought at the time about a cheaper version.
    I guess if you can get one cheaper, I would go for that !
  1. Replies: 22
    Last Post: 18-01-2022, 05:45 PM
  2. Replies: 0
    Last Post: 12-01-2012, 07:07 PM
  3. Please Help rear door wouldn't lock from inside (using 'lock' button)
    By angermayer in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-05-2011, 07:58 AM
  4. Please Help Sticky door lock
    By troggy1969 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-03-2011, 03:59 PM
  5. Sticky drivers door lock
    By Izalman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2007, 07:23 PM
