Thread: VAG-COM cable ?
  1. VAG-COM cable ?
    Bristol
    Ok bought a cable , and it doesnt seem to fit my purple 16 pin connector under my ashtray on my 1999 sharan 1.9tdi
    have i got the wrong cable , i thought a cable was a cable and they were all the same
    cable says KKL VAG-COM on it and it connects to via a serial 9 pin on the pc itself
    So do i now have a worthless cable ???
  2. Re: VAG-COM cable ?
    Apr 2007
    Lancashire
    The end of the connector on the cable is generally quite flexible, it may be slightly deformed, and need a little more pressure and wiggling to get into the tight connector.
  3. Re: VAG-COM cable ?
    Oct 2005
    Do you have a picture of the business end of the cable?
    Sometimes the surround of the port is a little too tight.
  4. Re: VAG-COM cable ?
    Bristol
    guys thankyou for your prompt replies , u r stars
    , ive pushed the lead connector on as best i can , it went on but not all the way so to speak ,
    but fired up my laptop went to port configure select com1 and guess what ,
    IT READ THE ECU WOOHOOOOO
    i went into fault codes and there was a coolant fault , as i disconnected this last week !! so cleared it , no problem !!!
    I got another fault , " interior sensor " and some number will look into that later i guess , didnt know there was interior sensors anyway !!
    thx guys
    ive also added myself to the VAG-COM location list to help out other members
  1. CD Changer cable
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-05-2007, 11:23 PM
  2. Bonnet cable
    By arfsvdub in forum Passat - Archive Topics
    Last Post: 09-05-2007, 04:27 PM
  3. ABS cable
    By tony_anon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-04-2007, 04:11 PM
  4. VAG-COM Cable doesnt fit
    By ashwizz1 in forum VCDS - General Questions
    Last Post: 15-04-2007, 10:22 AM
  5. Cable for use with VDS Pro
    By NickW in forum VCDS - General Questions
    Last Post: 10-04-2007, 04:28 PM
