Thread: A4 running issues
  1. A4 running issues
    Jan 2012
    Newbury
    I have a 2ltr A4 fsi 03 petol, had problem starting first thing in the morning, took it in to garage and replaced the air flow sensor, it cured the problem but then when driven for a while and left for half an hour it was a sod to start again, and running lumpy, the mechanic said it was probably the coolent temp sensor, which i have replaced, but still have starting and running problems, it has also cut out on me for no reason, just reved up and cut out, it started straight away and ran ok, has anyone got any ideas cheers Andy 123L
    Mod edit - Moved to correct section.
  2. Re: A4 running issues
    Feb 2010
    Sudbury
    Agree with coolent temp sensor (did you change the right one)not the rad one but the one on the block.When it reved up and cut out that indicates fuel starvation. Can you get the fault codes checked ,then let the forum know and you will get a lot of help otherwise you are P-----G in the wind.
  3. Re: A4 running issues
    Jun 2006
    Cardiff
    If you fitted a genuine VAG CTS it's unlikely to be at fault, but if you fitted an aftermarket CTS then that's most likely the cause of your problem.
    You really need to get VAGCOM/VCDS diagnostic done, but beware a faulty CTS doesn't always cause the ECU to throw a fault code unless it's gone open circuit or intermittent. Best to look at VAGCOM engine measuring block 02 which shows the temp the ECU is seeing from the CTS.
    B6 A4 Avant 1.9 TDI 130 Sport (6) Moro Blue, GMBH S Line Kit, Decatted, remapped to 165bhp, EGR delete, Goodyear Eagle F1 Asy's, Full Leather, Cruise Control, Bose, Audi phone prep, Cool Glove Box, Parking Sensors, Rear privacy glass.
    Seat Ibiza 1.2 TSI FR 3 door Lima Green.
  4. Re: A4 running issues
    Jan 2012
    Newbury
    Thanks Ron for your reply, and yes i did replace the sensor on the back of the block, car needs an m. o. t. in a few weeks so will see if garage can get the fault codes then .
  5. Re: A4 running issues
    Mar 2011
    Kendal Cumbria UK
    Was it a genuine VAG part though, as its a well known problem that the aftermarket ones from fuel parts or the likes are no good, same goes for MAF sensors, only fit genuine VAG ones.
    Dan
    2002 A4 B6 2.5 TDI Quattro Sport - Mods to date... Too Many To List!
  1. Polo 1.6 P plate running issues
    By JustinM3 in forum Polo - Derby - Lupo - Fox
    Last Post: 24-09-2009, 07:31 PM
  2. Starting and running issues.
    By PJMK3GTI in forum Golf MK3 - 1993 - 1999
    Last Post: 12-02-2009, 06:00 AM
  3. Please Help Audi 80 coupe 2.6 v6 running issues
    By bagpipingandy in forum 80 - 90
    Last Post: 28-01-2009, 11:51 PM
  4. hi everyone (running issues)
    By muskey01 in forum New Member Introductions
    Last Post: 22-04-2008, 08:53 PM
  5. 83 polo running issues
    By Dave83polo in forum Polo - Derby - Lupo - Fox
    Last Post: 08-03-2008, 03:49 PM
