Thread: Reg plate lights staying on
Results 1 to 10 of 18
  1. Reg plate lights staying on
    Jul 2006
    Hello all, My father has a W reg 1.6 gxli Octavia, his battery has been draining recently, check the drain the other day which was 0.16a. could see anything a miss, went to car following day, battery was stone dead.
    when i connected jump leads to the battery i looked for a radio left on or interior lights. I found both registration plate bulbs were on, tail lights and side lights were off and the switch was in the off position. Also the dash lights were on, not like the abs/eml light, just the green dash/console lights. After starting the car i couldn't get the fault to replicate again, however it has happened when i've not been about and dad has had to phone the aa for a jump start.
    Thought i'd have a look to see the bulbs werent the wrong way round, removed the tailgate rubbers and wiggled the wires to see if i could get anything to change...nope
    Anyone heard of this or had this problem?
  2. Re: Reg plate lights staying on
    Apr 2012
    cheshire
    hi,
    i have this exact problem with a passat b5.5. Did you resolve the issue as im stumped!
    thanks
  3. Re: Reg plate lights staying on
    Apr 2012
    cheshire
    Also my number plate lights are stuck on????
  4. Re: Reg plate lights staying on
    Were I is Now
    Old one but just seen the same on a vw polo.....if we tap the light rotary switch it lights the reg plate lights and iluminates the dials (bacground)......so I'm guessing its a faulty switch there or......duff ignition one being funky maybe?? Either way flat battery by morning...I've pulled the swich for now to see what it does in the morning.....
    2010 S4 in exclusive classic red and every option under the sun...as well as my 80 cabriolet 2.6e auto fun day car...not forgetting a slightly Smashed but saved waiting for some repairs 01.5 B5 A4 2.4SE Tip - Votex body kit, Hidden Microwave PDC, Pirelli X-Pressure TPMS, Hardwired Bel RX65e, Lamp Guards...and the exclusive Red Logo Audi Sport Valve Stem Caps!
  5. Re: Reg plate lights staying on
    Jul 2006
    Bloxham, Oxon
    I've got this same problem on an 07 Octavia VRS - number plate lights permanently lit when everything on the car is switched off - also got a bulb failure warning light on dash and check registration plate lights message. All the bulbs on the car are working OK.
    Any ideas ? I can see others have had this problem but I can't see any answers
  6. Re: Reg plate lights staying on
    Jul 2007
    glasgow
    35 Post(s)
    Must be faulty switch
    Have you replaced any other bulbs ?
    If you move switch to the left or right ever so slightly in the OFF position ..................... do the lights go on or off ?
  7. Re: Reg plate lights staying on
    Jul 2006
    Bloxham, Oxon
    Thanks Niall I'll put one of the no-plate bulbs back in & check that out.
  8. Re: Reg plate lights staying on
    Jul 2007
    glasgow
    35 Post(s)
    ok keep us updated
  9. Re: Reg plate lights staying on
    Jul 2006
    Bloxham, Oxon
    Still no joy - the number plate lights stay on 24/7 even with the light switch unplugged ! Help !!
  10. Re: Reg plate lights staying on
    Jul 2007
    glasgow
    35 Post(s)
    Have you got a multimeter ? I think you need to check you have power at Fuse number 4 with switch on and then no power with switch off. Check your handbook & number 4 Fuse does indeed do the lights.
    If the car is a hatchback .................. then the only other thing could be the actual wiring at the tailgate hinge ! Cut the bottom of the outer sheath so the cut allows water to escape rather than enter, and have look at the wiring. Is it covered in green gunk ? Are there wires broken and touching , causing a short ?
    You might be able to check the wires without cutting it.
  1. Please Help Reversing lights staying on
    By 996jimbo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-07-2011, 03:32 PM
  2. dash lights intermitant and interior lights staying on for ages
    By mystic.bertie in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2011, 06:27 PM
  3. indicator lights staying on when used ?
    By deamie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2010, 01:14 PM
  4. Rear Number Plate Lights - V Reg Polo
    By WesleyP in forum Polo - Derby - Lupo - Fox
    Last Post: 04-06-2009, 06:44 AM
  5. Please Help indicator lights staying on
    By spudyclur in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-03-2009, 02:22 PM
