Thread: RearNumber plate screw help
  1. RearNumber plate screw help
    Jun 2009
    Winchester
    Please can someone confirm the screw size needed for the rear plates? I am a total noob and need to know the size and type of screw if i went to a UK hardware store. Audi garage is too far to drive.
    I am 100% screwing them in so other options are not an option.
    I am not going to Audi for them so if i was going to a normal hardware store what would i ask for?
    Thanks!
  2. Re: RearNumber plate screw help
    Jun 2010
    Lincoln, Lincolnshire
    Wrong section, but you could just use a normal screw that fits the hole, a bit of trial and error required. Alternatively, you could get some silicon, seal up the holes and use some 3M double sided foam tape and stick it one with that. I did this about a year ago and even pulling the plate it wont come off. And it looks nicer with no holes on the plate.
    But yes, wrong section. Please administer a sharp slap to the wrist, before Esh does!
    Rich
    Headlight Conversion, 2x8000k HID kits, De-cat downpipe, .216 Nozzles Boost Gauge, Colour changed on climate control and all buttons, LED instrument cluster, LED number plate lights, LED rear/brake lights, Lowered 40mm on SPAX springs. Soon to have GT1749VA
  1. Screw size for rear number plate
    By Mr Tibbs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-01-2012, 02:43 PM
  2. Question Very Quick Question!! Bleed Screw
    By Grolly in forum Polo - Derby - Lupo - Fox
    Last Post: 21-06-2011, 04:43 PM
  3. Should i SCREW it?
    By phil miller in forum Chat - Anything with wheels
    Last Post: 09-08-2010, 11:22 PM
  4. coolant bleed screw sheared?
    By MATN in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-07-2009, 01:00 PM
  5. Screw in aerial needed for B5 passat please!
    By P Adams in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2009, 10:27 PM
