Thread: Golf TDI Servicing advice
  1. Golf TDI Servicing advice
    Dec 2011
    Swindon
    9 Post(s)
    I am due to service the car in the next month or so, oil and filter, air filter, fuel filter. It my first one on a Golf and not sure which way to approach the air filter. At a service station lavy on the M4 there was an advert for me to read whilst doing the 'shake' about either K&N filters or one that lasts a life time and is 'machine washable'. given they are more expensive than a normal vw/bosch one,but last longer, and am lead to believe give you better fuel ecomony, would it be classed as a 'Modifaction' by insurance companies?
    advice on all elements would be useful thanks.
  2. Re: Golf TDI Servicing advice
    May 2010
    Devon England
    Quote Originally Posted by geoff eeles View Post
    Over the years i have fitted many K&N air filters and have seen many cone filter (even on diesels) TBH on your TDI stick with fitting a genuine one, dont cost a fortune, the k&n dont make much if any gain in MPG
    and YES technicley it is a mod and you should inform your insurance, even tho its just an air filter
    VCDS HEX+CAN CODE READING AND RECODES
    OWN A MK5 GOLF TDI JOIN THE GROUP https://www.vwaudiforum.co.uk/forum/group.php?groupid=23
    2004 mk5, Viezu 140bhp Re-map, GTI front bumper, side skirts, GTI 18in rep wheels, Jamex coilovers, R32 speedo cluster, MFSW, White Roose Motorsport coolant hose's, GTTDI interior, centre consol armrest and ipod dock, leather handbrake lever
  3. Re: Golf TDI Servicing advice
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Stick to original parts. I know thats not what you want to hear, but that is how vw's are designed and original parts will keep the dirts out better. Do you really want to put your filters in a washing machine?
    Audi A7 3.0TDi 2011 180k miles, engine code CLAB 204bhp 2WD
  4. Re: Golf TDI Servicing advice
    Oct 2007
    The problem with K+N filters and the like, is that you have to wash them and re-oil them which WILL sooner or later kill you MAF sensor,(oil from filter getting on the sensor) and at about £80 a pop, its not worth it, I know by experience. stick with a standard air filter, the r32 comes with the same air filter as a TDi, so that says it all.
  5. Re: Golf TDI Servicing advice
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    Fitting a "performance" air filter to a standard VW TDI is bit like buying running shorts for your granny. She might look cool but she will not run any faster ! The VW standard air filter is capable of suppling much more air/oxygen to the engine than the engine needs.
    Skoda Octavia II SE 1.9PD TDI
  6. Re: Golf TDI Servicing advice
    May 2008
    In addition, Standard filter approx £15!
  7. Re: Golf TDI Servicing advice
    Dec 2011
    Swindon
    9 Post(s)
    i will go for VW Gen parts on these things. can't be taking any chances with such a furtherbred.
    Robnelson76 Guest
    I had a K&N fitted to my previous Saab 9-5 2.3t for 150,000 miles. I bought it because at £40 it was cheaper than repeated £25 for paper filters and I was doing 4 to 5,000 miles a month.
    I washed it about every three services and re-oiled it. I never had any noticeable issues with any sensors or anything.
    For a car I intend to keep for a while, I'd fit a K&N on economic grounds every time from my last experience.
    Rob
  1. Question Servicing on a MK5 VW Golf GT TDI 140Bhp
    By TonyDB in forum Golf MK5 - 2004 - 2009
    Last Post: 09-06-2010, 06:16 PM
  2. Golf GT TDI Servicing
    By marc1979 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-03-2008, 09:11 PM
  3. Golf tdi 1.9 mk3 servicing/cambelt
    By veedub76 in forum Golf MK3 - 1993 - 1999
    Last Post: 28-01-2008, 09:47 PM
  4. Servicing Mk4 golf gt tdi 150
    By k3v in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2007, 10:51 AM
  5. Can I have some advice on servicing
    By spiderlover in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 15-02-2007, 05:30 PM
