Thread: Audi a4 (b7) 2.0t fuel pump problems (has there been a recall?) - fuel metering implausible signal
  1. Audi a4 (b7) 2.0t fuel pump problems (has there been a recall?) - fuel metering implausible signal
    Hi, I have a 54 reg Audi a4 (B7) 2.0t and the engine managment light comes on stating:
    Mode 03: Emission related fault code
    Address 7E8
    p0089 - Valve for fuel metering (N290) Implausible Signal
    I think the valve at the top of the fuel pump, the one which the electrical connector plugs in to needs replacing but I think I have to buy the whole fuel pump to get this bit, is this correct?
    Has Audi replaced this fuel pump with another? The part number is 06F 127 025 B and I read somewhere it might have changed to 06F 127 025 F.
    Any help on this would be grate.
    Thanks,
    Kevin.
  2. Re: Audi a4 (b7) 2.0t fuel pump problems (has there been a recall?) - fuel metering implausible signal
    Aug 2010
    Sheffield
    Hi Kevin. My a4 has done the same. Have you had it sorted. My engine management light has been on for a week now.
    Thanks.
    Mark.
  3. Re: Audi a4 (b7) 2.0t fuel pump problems (has there been a recall?) - fuel metering implausible signal
    46 Post(s)
    Get it scanned for faults?
    An engine light can mean anything.
  4. Re: Audi a4 (b7) 2.0t fuel pump problems (has there been a recall?) - fuel metering implausible signal
    Aug 2010
    Sheffield
    Its come up as P0089. fuel pressure regulater 1 performance. any ideas? and any recalls?
    cheers.
  1. Question fuel pump recall - further costs?
    By rbloor in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-06-2010, 03:52 PM
  2. Fuel Pump Recall!!!
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-03-2010, 09:04 PM
  3. fuel pump problems
    By splasher in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-08-2009, 12:44 PM
  4. Ive got the Passat fuel pump recall
    By jonsey24 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-05-2009, 09:57 PM
  5. Fuel Metering Distributor 1991 8V cabrio
    By stumx in forum Golf MK2 - 1984 - 1992
    Last Post: 27-01-2009, 08:04 PM
