Thread: Water in boot below space save spare wheel
  1. Water in boot below space save spare wheel
    Sep 2011
    Melksham, Wiltshire, UK
    Just checked my tyre pressures today and also the spare. Took it out to check and noticed a load of water in the boot
    Checked the rear carpets, dry - checked the rear wash wipe didn't leak when operated, OK - no other visible holes!
    Anyone any ideas on this - 2007 MY A3 - any issues or known problems with this happening?
    1999 GTi Turbo - Turbo Technics uprated turbo, Forge charge cooler, Jabba remap, Milltek SS system, Brembo GT brakes, Koni Sportlines, Neuspeed ARBs
  2. Re: Water in boot below space save spare wheel
    Jan 2010
    Wakefield, West Yorkshire
    Have you had the boot liner off to check for leaks ?
    Very common fault is either the connector leaks (or breaks when frozen ) and water runs down the inside of the boot lining or the motor corrodes inside and leaks.
    New wiper motor is the usual repair.
  3. Re: Water in boot below space save spare wheel
    Sep 2011
    Hi Mike,
    I had this problem in my 1999 Golf Gti Mk4, where the pipe was loose off the rear wash connector on the wiper motor. I would have expected this design issue to have been resolved on a 2006/7 car, especially after the numebr of faults this has caused, so I didn't look at that as a possible problem! However, as I use green washer additive in the reservoir, I syphoned up some of the water into a glass container and the water is totally clear - which I now suspect to be rain water.
    Looks like the misses will be soaking the car with a hosepipe again tomorrow with me in the boot!!! Ha Ha
  4. Re: Water in boot below space save spare wheel
    Jan 2011
    East Kent
    When I first bought my car, I also had a small amount of water in the spare wheel area. I wiped it up and it hasn't come back since...Thankfully. I hope that you get to the bottom of it.
  5. Re: Water in boot below space save spare wheel
    Jan 2012
    Coding Something
    Could be the boot seal tbh, known this to happen & what it does is goes down & round the seal, settles at the bottom & then dribbles into the spare wheel well, as you say hose pipe job.
  1. Water in spare wheel bay
    By Hemtt in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 22-02-2013, 11:34 PM
  2. Water in spare wheel well
    By Tomcaj in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-01-2012, 06:07 PM
  3. A4 Saloon, Water in spare wheel well
    By Probs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-01-2011, 12:23 AM
  4. Spare/space saver wheel needed
    By FoxA6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 17-06-2009, 06:05 PM
  5. Please Help Water in spare wheel well
    By in forum Chat - Anything with wheels
    Last Post: 01-01-1970, 01:00 AM
