Thread: Audi A2 Tdi error code P3101 Motor for a inlet manifold flap
  1. Exclamation Audi A2 Tdi error code P3101 Motor for a inlet manifold flap
    Aug 2006
    I have the following Fault code error message P3101 Motor fault Inlet Manifold Flap - Can this be fixed or does to need to be replaced? The engine warningl ight constantly stays on and i need to fix the problem on a cheap if i can so that the light goes off. I notice sometimes that when i turn the heating on it does smell of exhaust odour at certain times - do you think it is assoicated?
  2. Re: Audi A2 Tdi error code P3101 Motor for a inlet manifold flap
    Sep 2007
    London UK
    19559/P3103 - Motor for Intake Manifold Flap (V157), Malfunction
    Possible Symptoms
    Higher fuel consumption
    Insufficient acceleration above 100-120 kmh
    Shutting off the engine is not nice and easy
    Possible Causes
    Intake Manifold Flap (V157) or the motor for V157 doesn't work well.
    Possible Solutions
    Check wiring and connections
    Check / Replace V157, but probably you have to replace the whole EGR
    Special Notes
    The Intake Manifold Flap (V157) has a function in the EGR and in shutting off the (diesel) engine.
    Audi A4 2.0 TFSi DTM, Quattro, 2006, 220 BHP, Sprint Blue, Multi Spoke Alloys, Light pack, Bi-Directional Xenons, Auto Wipers, Recaro/Electric/Leather/Alcantara/Heated/Memory Seats, Under seat storage, Carbon Fibre spoilers, Carbon Fibre trim inserts, RNS-E Sat Nav, Bluetooth Phone Prep, SDS, FBMFSW, .....
  3. Re: Audi A2 Tdi error code P3101 Motor for a inlet manifold flap
    Aug 2006
    The strange thing is that the light was not on when i purchased it - ity only came on after i repalced the CAT which was faulty - surely that could not casued the intake manifold flap to fail hence the warning light comming on. I usually gert 45-47mpg compared to 61mpg that is claimed - i put in 20 litres of fuel and get just over 200 miles with a mixture of urban driving. The temperature needle stays at 0 for quite some time and then climbs up slowly to 90 where it stays - is that unusual?
  4. Re: Audi A2 Tdi error code P3101 Motor for a inlet manifold flap
    Mar 2013
    peterborough ,united kingdom
    I did repair that there is a gear wheels made from plastic and one of them was damaged so i clean them out and put them back to try all ok now bat code was 19559/P3103(V157). I writen somthing into the picture but its in czech lang.2013-03-04 11.30.44.jpg
    If you find nothing wrong with gears so possibly motor gon to Heaven take them off and try them with your car battery and a wires. Thats what i did now its work as before
  1. Inlet manifold flap activator replacement
    By Malcolm in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2012, 11:19 AM
  2. Please Help Inlet manifold flap and glow plugs.
    By Dee84 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 04-06-2010, 08:33 AM
  3. Motor for intake manifold flap
    By stephen k in forum Golf MK4 - 1999 - 2004
    Last Post: 31-05-2009, 05:47 PM
  4. Inlet manifold flap
    By davegilsenan in forum Audi A3 - Archive Topics
    Last Post: 02-03-2009, 03:48 PM
  5. Motor Intake Manifold Flap
    By daveaustin in forum Archive posts
    Last Post: 06-12-2007, 04:39 PM
