Thread: potentiometer on accelerator pedal. *
  1. potentiometer on accelerator pedal. *
    Jan 2009
    potentiometer on accelerator pedal. *How can I test it and reset it if need be . been looking with vag com and can't find it any ideas it's an A6 2.5 tdi *thanks*
  2. Re: potentiometer on accelerator pedal. *
    Jan 2009
    towcester northants
    you should be able to find the pedal in measuring block data to see if its working
  3. Re: potentiometer on accelerator pedal. *
    Jan 2009
    Ok thanks found it but it's doing notting as it should when idling so back to square one again . Does anyone know the login for my engine as I've tried 26262 as advised but it must be wrong as it keeps dropping session when I put it in and according to Ross tech when it does that it's the wrong code
  4. Re: potentiometer on accelerator pedal. *
    Ambler, PA, USA
    Can we back up? I'm a little dense.
    You found the measuring values for the gas pedal potentiometers? And both are reading nothing? Is that what you are telling us? If this is correct then there must be a wiring problem to the potentiometers. You will need to pull out your wiring diagrams and a meter to figure that out.
    Why are you trying to log into the engine ECU? Measuring values do not require logins. Are you trying to do something else now?
  5. Re: potentiometer on accelerator pedal. *
    Jan 2009
    Sorry yes I suppose I'm mixing 2 things up here what I'm saying is the pedal is 0 percent on idle which is normal I guess as I was told if its higher on idle I have a problem. Then when I want to login to controller to do other things the code I've found is 26262 which I think is wrong code as it keeps losing connection
  6. Re: potentiometer on accelerator pedal. *
    Ambler, PA, USA
    In order to help with the login, a copy of an autoscan report would be real helpful.
    But then I come to the question, what are you trying to do and why are you thinking you have a problem? You have yet to describe what is wrong with the car and why you are chasing an idle issue/pedal issue/engine ecu issue. Could you give us the big picture and then ask for our advice? Because so far, I remain confused.
    But then as I said, I am pretty dense.
  1. Question a4 b6 accelerator pedal 2.5tdi
    By VAGMAN54 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 09-02-2011, 08:21 PM
  2. Accelerator Pedal
    By nicky900 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-12-2008, 09:03 PM
  3. Accelerator Pedal
    By JoGibson in forum Golf MK4 - 1999 - 2004
    Last Post: 19-10-2008, 03:16 PM
  4. Please Help Accelerator pedal
    By firestarter in forum 80 - 90
    Last Post: 27-09-2008, 11:04 PM
  5. Accelerator pedal
    By Cossie 2.5 in forum Golf MK4 - 1999 - 2004
    Last Post: 22-07-2007, 12:32 PM
