Thread: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
  1. Question GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    Jonny88 Guest
    Hi all,
    Over the last few months I’ve started noticing a clunking noise coming from the front end of the car. It’s got progressively louder and more noticeable recently. I can’t think of any other way of describing it other than a clunking noise that occurs when I drive through pot holes and on generally bumpy and uneven road surfaces.
    I had the rear bushes replaced in July so sort of think I know what I’m looking out for and think it might be the same scenario on the front as the sound and feeling is very similar. To further strengthen the case, when I had the rears done in July, it was noted on the service sheet that “Offside front suspension mounting deteriorated”.
    I’ve owned the car from 55k and it’s now at 103k. According to the service history it had never had the mountings replaced, front or back, before I got it.
    Does it sound reasonable to suggest at this stage that it’s probably the front suspension mountings causing the clunking and rattling sound?? Or another thought was the anti-roll bar bushes?
    Any suggestions and help is much appreciated.
    Thanks a lot in advance.
  2. Re: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    Dec 2011
    Swindon
    9 Post(s)
    i have noticed a similar noise coming from my 130 Tdi. I know that the front and rear lower suspension arm bushes (this was noted on the MOT certificte), they are about £6-10 eah for the bushes from VW. Not sure how to change them as my Haynes has not been delivered in my local Halfords, but theres sure to be a guide on here somewhere.
  3. Re: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    May 2010
    Devon England
    could be the top shock mounts, shocks, anti roll bar links or bushes or as above the bottom are bushes, best get it looked at to make sure and then get the parts fitted
  4. Re: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    Jonny88 Guest
    Cheers for that Phil. Going to have it looked at soon.
  5. Re: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    Jan 2012
    Bedford
    I had a simular problem with my mk4 Golf. It was the anti roll bar bushes. The bushes are cheap but VW will was £200 to fit them. I had mine fitted by a mate. Good luck
  6. Re: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    Dec 2011
    Swindon
    9 Post(s)
    there may be some on here who could do it for you!
  7. Re: GT TDi 150: Clunking noise from the front end - are the front suspension mountings to blame?
    Jan 2010
    telford uk
    More than likely bushes, but you will need to get the car up in the air to do it, ideally. Having said that, just check your wheel nuts are tight first :-P
  1. Please Help A4 1.9 TDI front end noise
    By Foogy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-05-2015, 11:20 PM
  2. Banging noise from tdi 150 front suspension
    By V9FOS in forum Golf MK4 - 1999 - 2004
    Last Post: 30-07-2009, 03:59 PM
  3. Clunking noise from front end
    By A8Phil in forum A8 - S8 - V8
    Last Post: 06-05-2008, 08:40 PM
  4. A6 2.5 Quattro front clunking noise
    By doggy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-01-2008, 10:36 PM
  5. A4 TDI 1.9 Front suspension noise?
    By tubbs in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-10-2006, 12:05 AM
