Thread: Mk 4 GT Tdi suspension
  1. Mk 4 GT Tdi suspension
    Mar 2007
    Hull
    Now then, after two years of driving an A3 1.8 T sport, i've rencent required a mk 4 GT tdi, I know the A3 isn't the best handling car in the world, but the golf is bloody awful! both standard cars, both 16' wheels but i had toyo tyres on audi and cheap budget ones on golf, should the golf have a stiffer suspension on par with audi being a GT? both have same mileage on, I think a suspension over haul is the way forward on golf!
  2. Re: Mk 4 GT Tdi suspension
    7 Post(s)
    It's true, it is very squishy.
    When I had my MK4 GT TDI I fitted eibach springs and sachs gas dampers. This lowered it 30 odd mm and totally transformed the handling. A rear arb will also further add to the handling although I never fitted one.
  3. Re: Mk 4 GT Tdi suspension
    Feb 2007
    South West
    With the Gt Tdi's the 130 bhp had standard golf suspension unless you had the option of sport suspension which came with the Montreal 2 Alloy wheels too. The 150 bhp comes as standard with the Gti sports suspension.
    Skidmark
  4. Re: Mk 4 GT Tdi suspension
    7 Post(s)
    Yes it they did.
    They were a 10mm drop from standard but still very squishy.
    A vital mod in mind view on the MK4 TDI's and mine had a tendancy to bottom out at the front very easily with stock suspension and bearing in mind how low the sump is anyway, it just makes sense.
    Ironically, although lowered, either with just better springs or coilovers, tightening up the suspension stops the bottoming out.
  5. Re: Mk 4 GT Tdi suspension
    Mar 2007
    Hull
    Quote Originally Posted by Skidmark View Post
    Skidmark
    it has the montreal wheels, i'll have to sort it, no fun!
  6. Re: Mk 4 GT Tdi suspension
    7 Post(s)
    If you do swap out the suspension, make sure you renew the front top mount rubber bushes and the bearing.
  7. Re: Mk 4 GT Tdi suspension
    May 2007
    knee deep in clunge
    14 Post(s)
    Also replace the rear axle bushes with the harder polly bushes and retro fit rear anti roll bar.Replace the front anti roll bar with a stiffer type and again polly bushes to all the front suspension,this will improve the feel and response but a lot of labour,try big boys toys in essex they have full suspension kits.I have done this for a family member and it was a differant car after,but it depends on your budget http://www.bigboyztoys.co.uk/shop/
  8. Re: Mk 4 GT Tdi suspension
    Mar 2007
    Hull
    Cheers all, just want a little firmer but not harsh, bushes definately, i'll keep you updated!
    Mk4 Golf GT TDI 115 £4000 / MK3 'bargain' banger requires 'box
  1. mk3 gti suspension
    By s194smith in forum Golf MK3 - 1993 - 1999
    Last Post: 09-04-2007, 04:01 PM
  2. Mk IV suspension
    By dessimpson in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 14-02-2007, 12:44 AM
  3. Suspension
    By Apophis in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 25-01-2007, 03:16 PM
  4. '98 A4 suspension qu?
    By tomyj81 in forum Archive posts
    Last Post: 15-01-2007, 12:01 AM
  5. Suspension
    By danj1005 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 11-01-2007, 04:35 PM
