Thread: Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
  1. Exclamation Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    Jul 2007
    any ideas for this problem in a golf gti mk3 98 (70k miles)?
    cheers
  2. Re: Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    Jul 2007
    Dorset, England
    On my Mk4 some water had corroded the wires between the headlight switch and dimmer switch etc.
    Might be worth getting some replacement switches off Ebay?
  3. Re: Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    Jul 2007
    how can i find out which of the wires they are? there's about a dozen coming out of the headlight switch.
  4. Re: Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    Jul 2007
    Dorset, England
    That's something that fortunately my mechanic dealt with
    Although changing just the switches, which turned out to be the main reason, was easily done by myself. Although this was on a Mk4 not a Mk3, so the process could be different. Worth checking with your mechanic maybe...?!
  5. Re: Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    Jul 2007
    Quote Originally Posted by Edwardo_TDI View Post
    i've actually already tested my switch in my parents golf and it works fine... so i guess it must be something else
  6. Re: Instrument panel illumination light problem... or "I can't see how fast i'm going at night!"
    Aug 2007
    I just spent a couple of days dismantling the dash on my daughter's 1.0 1998 Polo as she couldn't see the instruments at night.
    All the warning lights worked, just no illumination. Couldn't find any bulbs to replace, no fuses blown...
    Eventually went to VW main agent for a fault diagnosis.
    The problem was that the rotary instrument dimming switch had been turned down....
    Yes I know I should have checked but she does have a degree.
    Try it !!
    Rgds dave
  1. Audi A4 Avant - Panel Display - "In 1 "or "In 2"
    By infrance in forum Audi A4 - Archive Topics
    Last Post: 05-03-2007, 03:20 PM
  2. Audi Q7 makes its debut at the "quattro Night"
    Last Post: 27-02-2005, 06:55 PM
