Thread: Passat 2002 central locking issues
  1. Passat 2002 central locking issues
    Nov 2006
    For some obscure reason when I activate the door locks from inside the car using the switch on the drivers door, all the doors lock then the passenger door lock pops back up. I find this very strange as they all lock satisfactorily using both the key fob and manually on the drivers door.
    Another intermittent trait is now and again the o/s rear door lock stays locked upon opening using the key fob. Sometimes it can take 3 or 4 presses to open this door.
    Please can anyone shed any light on any of these issues?
  2. Re: Passat 2002 central locking issues
    london/ UK
    The lock actuators are deffective. I am breaking a vw passat estate at the moment, all parts going cheap... Please get in touch if you need anything. Regards,
    Chris- 07789912128.
  3. Re: Passat 2002 central locking issues
    Nov 2006
    Quote Originally Posted by adamss24 View Post
    Chris- 07789912128.
    If the lock actuators are defective, why does the problem with the passenger door only happen from within the car and not from the key fob?
  4. Re: Passat 2002 central locking issues
    135 Post(s)
    2033 Post(s)
    It just happens that way, a fault code read of the convenience system will show an implausible signal from that lock unit, it happens a lot.
  5. Re: Passat 2002 central locking issues
    Tried to PM you re the passat parts but message store is full, make some space, Chris
    Chris- 07789912128.
  6. Re: Passat 2002 central locking issues
    Nov 2006
    Quote Originally Posted by rosco View Post
    Ah I see. I have my own fault code reader. I'll give it a check when I get a chance.
    Thanks loads for the information. It is very much appreciated.
  1. '02 Golf central locking issues
    By hooky1742 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-04-2011, 05:25 PM
  2. Retrofitting Central Locking to a 9N (2002)
    By vc-10 in forum Polo - Derby - Lupo - Fox
    Last Post: 29-11-2009, 04:51 PM
  3. Please Help Audi Central locking issues
    By bagpipingandy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-03-2009, 11:18 PM
  4. Central Locking Issues
    By Shadow in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-11-2008, 11:28 AM
  5. S3 (2002) central locking coding
    By A4Ade in forum VCDS - General Questions
    Last Post: 25-05-2008, 06:36 PM
