Thread: Electronic Parking Brake woes help needed
Results 1 to 9 of 9
  1. Electronic Parking Brake woes help needed
    Jul 2007
    Hi, I have an 07 Passat 2L TDI SE with 92k on the clock, came home tonight to go out in it & parking brake wont release, warning lights are on & audible tones sounding ffs. Rang up local VW inchscape in Shrewsbury, thay told me to dissconect the battery for 3 minutes & it should reset,, tried it twice with no luck, tried cycling ignition with no luck,, how can i realease this damn brake so at least we can drive the car? VW just said it will have to be recovered ***,, got to be a way. Please bear in mind I am a complete car novice,, I can change oil and filters, front brake pads, but this seems way beyond me unless someone can come up with an easish solution,, vw also said it might be the switch ? so please can anyone help me. mucho apppreciated.
  2. Re: Electronic Parking Brake woes help needed
    it is most likely the switch which is causing the problem,i suggest you get yourself new one tomorrow,very easy to replace
  3. Re: Electronic Parking Brake woes help needed
    Norfolk
    It;s easy to release the epb. Work out which wheel is stuck.
    Jack up and remove wheel.
    Unbolt caliper motor (2 torx screws)
    Back off cetral caliper torx drive by one turn.
    Refit epb motor and wheel.
    Get switch replaced.
  4. Re: Electronic Parking Brake woes help needed
    Feb 2010
    Devon
    https://www.vwaudiforum.co.uk/forum/s...oftware-update
    I replaced my switch about a month ago and started to get the same faults you have - so see the above thread
    06 (my2006) Passat Estate 2.0 TDI SE 140bhp (BKP110710), MFD2, Premium Phone, 6CD Multichanger, MFSW, 4 new injectors!!!
  5. Re: Electronic Parking Brake woes help needed
    Jul 2007
    well I took motor off (no cracks) the stuck wheel and backed off torx screw but maybe more than one turn before wheel freed,, put all back together fitted new switch, still saying brake problem have both parking brake lights illuminated one yellow one red, and an annoying audible bong while driving, at least i can now drive it to local garage, havnt tried parking brake since incase it sticks again,, hope garage can diagnose and sort it out,, what else can cause brake to stick on?
  6. Re: Electronic Parking Brake woes help needed
    Norfolk
    It is usually a seized gear cluster in the epb motor housing. make sure the garage know what they are doing or you will end up paying for two new calipers and even an epb control module.
  7. Re: Electronic Parking Brake woes help needed
    135 Post(s)
    2040 Post(s)
    I had one last week, split casing and water damage to offside rear calliper, it would not release. Jacked it up, pulled the motor off, wound the thread back and drove it back to work. Fitted a new motor, nothing. Sent the car to VW for a software flash, fried ECU. VW UK only have 88 ECU's in stock so it is not a big problem, is it! I ask you, what was wrong with a lever and cables?
  8. Re: Electronic Parking Brake woes help needed
    Jul 2007
    car is in garage, no power getting to passenger side motor,, doing a software update to see if that fixes it(after i fitted new switch) but looks like its a fried control box, going to see if its reparible first, or if it needs a new one at £279 plus vat ffs,, give me a cable brake any time,, going to be a big bill for a stupid problem,, on the plus side whaen i telephoned VW shrewsbury gave them my reg to ask for new EPB control box they told me my car is due a recall all new injectors & wiring £2k so thats being done on 2nd Feb.
  9. Re: Electronic Parking Brake woes help needed
    135 Post(s)
    2040 Post(s)
    The injectors are not a £2k job any more, they are now less than £200 each retail, never mind what they cost VAG DE.
  1. A6 Electronic Parking Brake
    By GLOVERGLOBAL in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 23-01-2012, 11:19 AM
  2. Please Help Electronic parking brake
    By chapel1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-12-2011, 07:28 PM
  3. Question Electronic Parking Brake
    By airspark in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-05-2011, 09:13 PM
  4. electronic parking brake [EPG]
    By gtijohnny in forum VCDS - General Questions
    Last Post: 17-11-2008, 01:40 AM
  5. Electronic Parking Brake
    By ondines_curse in forum Scirocco - 2008-
    Last Post: 19-09-2008, 09:55 PM
