Thread: No spare bulb kit for Mk6?
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
  1. No spare bulb kit for Mk6?
    Jul 2011
    SANDOWN, isle of wight
    I am trying to get hold of a bulb kit for my MK6 Golf, as all the bulbs seem to be push in or different to any I already have. My local dealer says there is not a bulb kit available. This seems a bit odd for a car that came out in 2009! Has anyone found a bulb kit available? I notice as well that the main beam is a H15 bulb also containing the DRL filament.
    Many thanks
    Ian
  2. Re: No spare bulb kit for Mk6?
    Jan 2009
    Quote Originally Posted by iandjm View Post
    Many thanks
    Ian
    Which is good thinking because the DRL being constantly on, the bulb only lasts about 1/3rd of the time, so you change headlight bulbs thrice as often. What do you recon about £22 each.
    http://img.photobucket.com/albums/v2...-09_092201.jpg
    2011 . Golf Match. 1.4TSI Manual 122Ps Steel Grey.
  3. Re: No spare bulb kit for Mk6?
    Jul 2010
    Oxford
    Quote Originally Posted by Rhigour View Post
    I think it is even worse than 1/3 of the time.
    I guess most people only use their high beam a small percentage of the time.
    If you use the high beam 2% of the time, the bulb will need replacing 50 x more often, compared with just high beam.
    On the other hand, a dedicate DRL bulb would need replacing just as often, but perhaps could be a cheaper bulb type.
    Presumably the headlight unit costs less to manufacture and install because it only has one bulb.
    LEDs are the future...
    Golf Match 2.0 tdi 140 Bluemotion tech, fogs, folding mirrors. Reversing camera didn't make it, so enjoying DAB.
    Other motor is a Nissan Pathfinder.
  4. Re: No spare bulb kit for Mk6?
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    I bought a bulb kit for my 2009 (2010MY) MK6 Golf from main dealer - part number 000 998 204 . Haven't had cause to use it yet but bought for continental touring.
    IMHO it's better to buy a long life bulb (LL on bayonet fitting) from VW than a cheap bulb from other sources. Quite apart from lasting longer the difficulty of changing bulbs ( scratched & bleeding hands) is drastically reduced in frequency. Also if a bulb kit is bought from some dealers, the dealer will fit them free of charge ( mine does).
    Skoda Octavia II SE 1.9PD TDI
  5. Re: No spare bulb kit for Mk6?
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  6. Re: No spare bulb kit for Mk6?
    Jan 2009
    Wrong headlight bulb, you need a H15 for the latest model with DRL's. What you could do is take the H7 kit which does the dip beam and all the other lights and add the H15 bulb to it.
  7. Re: No spare bulb kit for Mk6?
    Jul 2011
    Stafford
    Not so sure about that! The DRL filament is under-run (which is why people complain that it gives a yellowish light) so I'd hope that it will last for years... time will tell of course.
    Chris
  8. Re: No spare bulb kit for Mk6?
    Jan 2009
    Quote Originally Posted by CJJE View Post
    Chris
    ? does that mean there is a voltage dropping resistor in circuit to run the bulb below 12V ?
    here is something I didn't Know.
    To comply with ECE regulation R-48, since August 2006 headlight lamps in cars with new type approval must be installed in such a way that the light source can be replaced using the manual’s instructions and the vehicle toolkit. OSRAM’s SNAPINLITE provides a simple and safe solution. It is already in successful use in the current sixth generation VW Golf. The front lights include OSRAM H15 dual filament lamps, which assume the full beam and daytime running light functions and are fitted with a SNAPINLITE base. In the Tesla Roadster electric car an H9B with OSRAM’s SNAPINLITE takes care of the full beam. With the H8B, H9B, H11B and H15 halogen lamps as part of OSRAM’s SNAPINLITE range the appropriate lighting solutions are available for all modern headlamp functions, which give OEM the opportunity to develop application-friendly lamps
    So no more having to get the garage to drop the front bumper and take the headlight units out to change the bulbs like my last Volvo V60 then !
  9. Re: No spare bulb kit for Mk6?
    Aug 2009
    oxford
    That would be the best bit of legislation the EU has managed so far. But and it is a full bodied but, vehicle manufacturers seem to ignore it, as very few cars can have both sides changed without taking half the under bonnet bits out first, or you need the hands of a 5 year old. I might be wrong,
    Golf mk6 GT TSI 160 3 door Black with convenience pack
  10. Re: No spare bulb kit for Mk6?
    Aug 2011
    Kidderminster
    The Roomster ones were a doddle, you need to get into the back of the light cluster to change the beam setting for driving on the Continent... Pity the Golf doesn't have that facility...
  1. Question Spare wheel kit
    By DougJohnSmith in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-02-2011, 06:43 PM
  2. anyone likely to have a PN or spare.......
    By v8slugger in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-03-2010, 07:09 PM
  3. installing Parrot BT kit and an xcarlink ipod kit
    By kipperphill in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 05-01-2010, 01:00 PM
  4. A3 05 plate spare kit needed
    By slinxy in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 31-03-2009, 08:24 PM
  5. How to remove the front Turn signal bulb socket to replace bulb
    By rg0115 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-04-2008, 10:47 PM
