Thread: improving allroad headlights
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
  1. improving allroad headlights
    Sep 2008
    Highlands
    12 Post(s)
    Hi All
    I would like to know what my options are and costs involved for improving standard allroad headlights. Mine are awful on dipped beam. Also reversing light is poor can i put a brighter bulb in without blowing the fuse ?
    Vin
  2. Re: improving allroad headlights
    Sep 2008
    Highlands
    12 Post(s)
    Anyone???????????????
  3. Re: improving allroad headlights
    Aug 2008
    Isle of Skye
    Quote Originally Posted by vinpetrol View Post
    You can fit xenon units to the front, I got mine off eBay for about 60 pounds. Probably a much better idea than brighter bulbs which could melt the wiring and plastic in the lamp
  4. Re: improving allroad headlights
    Ayrshire, Scotland
    18 Post(s)
    You can by xenon bulbs for less than that, do you mean HID,
    I Just fitted an HID kit to mine, ebay cheap specials £30 for the kit, H1 6000K, definatey better light especially in wet/poor weather, my opinion not a hugh difference in the brightness of the light coming from them but more a better use of the light, white light seems to light up the subjects in front much better, especially in rain (plenty of that here!!)
    legally to fit HID's I think you are supposed to change the light unit, for one designed for difusing the light from HID bulbs, have self leveling lights &/or suspension and headlight washers, the standard allroad has 2 out of 3, !!
    to fit the ballasts/wiring properly I removed the headlights which means bumper off job, but all managable in about 2 hours,
    regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  5. Re: improving allroad headlights
    Aug 2008
    Isle of Skye
    Yep, I meant HID with the ballasts. I did the same as you, but my kit was a tad more expensive. I found it to be a very big improvement but my bulbs were 4300K so they should be brighter than the 6000's.
  6. Re: improving allroad headlights
    Ayrshire, Scotland
    18 Post(s)
    I couldn't decide 4300k or 6000k yes the 4300k should be brighter but eventually went for the 6000k as I bet myself anything would be better than the standard A6 headlight. You also get what you pay for, perhaps thats why yours could be brighter!!
    I just changed the fogs, side and full beam to Xenon whiter burning bulbs to tie them all together, the old ones just looked yellow next the to HID's!!
    regards
    Andy
  7. Re: improving allroad headlights
    Sep 2008
    Highlands
    12 Post(s)
    Hi again Andy
    Thanks for the help guys. Can you clarify what you mean by HID with ballast ? also any tips on improving the reversing lights ?
    Vin
  8. Re: improving allroad headlights
    Ayrshire, Scotland
    18 Post(s)
    Hid's are high intensity discharge, if you search ebay for hid kits they come complete with every thing you need, you need to choose the bulb type and the brightness, the main beam on my allroad is h1 bulbs, so example search, h1 hid kit 4300k, yours may differ if they are newer headlamps.
    Regards,
    Andy
  9. Re: improving allroad headlights
    Aug 2008
    Somerset
    The 4300K bulbs are closest to the OEM HID lights, I am running these and they make a big difference.
    If you find a set with a smallish ballast it will fit inside the headlight fitting.
    Sep 2008
    Highlands
    12 Post(s)
    Is there an issue with the legality of these kits? Would they need to revert back to original at MOT time?
  1. allroad headlights
    By ben0069 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-12-2011, 11:19 AM
  2. 2007 audi allroad adaptive headlights
    By atillla71 in forum VCDS - Help Requests
    Last Post: 16-06-2011, 11:58 AM
  3. Replacing headlights and sidelights - 2006 A6 Allroad (C6, 4F)
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-01-2010, 01:01 PM
  4. improving my fuel consumption?
    By vegvan in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 11-03-2008, 11:45 PM
  5. Improving my 90 2.3E
    By windy1978 in forum 80 - 90
    Last Post: 12-12-2007, 06:19 PM
