Thread: Broken key
  1. Broken key
    Yeovil
    It's not a disaster because i have another key, but in my wisdom to fix it, i also tried to find out why the remote locking wouldn't work. Figured the batteries were dead so i took it apart. Batteries are fine, cleaned it out and bent the terminals slightly to make sure of good contact. Still not working.
    Am i right in thinking it's lost it security settings when the batteries were removed?
    Can anyone tell me how to reprogram the second key?
    It's a '99 TDi SE
  2. Re: Broken key
    Jul 2007
    To program the remote on a '99 Passat do the following:
    1). Switch ignition on with key that is already programmed
    2). Manually lock the driver's door with new key / remote.
    3). Press the lock or unlock button on the remote.
    4). Wait for at least 1 second.
    5). Press the lock or unlock button on the remote again.
    6). The vehicle horn should now sound.
    7). Remove both keys and try.
    A maximum of 4 remotes can be programmed.
    Up to 1998 Passat remotes can only be programmed with the use of diagnostic equipment.
  1. broken air con 2000 bora
    By retrop997 in forum Bora - 1998 - 2005
    Last Post: 18-06-2007, 05:35 PM
  2. Audi 80 is broken :(
    By Ian W in forum 80 - 90
    Last Post: 13-06-2007, 09:28 AM
  3. window clips broken!!!
    By mack10 in forum Archive posts
    Last Post: 12-06-2007, 08:57 PM
  4. Cat converter broken
    By norrie rugger head in forum Passat - Archive Topics
    Last Post: 13-04-2007, 10:51 PM
  5. I've been broken in to!
    By ChrisH in forum Passat - Archive Topics
    Last Post: 12-01-2007, 10:54 PM
