Thread: 2007 A4 cruise control stopped working
  1. 2007 A4 cruise control stopped working
    Sep 2011
    Derby
    Cruise control has stopped working all of a sudden. Tried pressing to set and nothing happened. No light on dash and cruise doesn't work at all.
    Looking in the manual I can't find a sepcific fuse for cruise control.
    Everything else seems to be working fine.
    Any ideas of where to start looking?
    Thanks,
    D
    May 2008
    Faulty brake or clutch pedal switch.
  3. Re: 2007 A4 cruise control stopped working
    Dec 2011
    Norway
    like said, clutch pedal switch ?
    If the switch is faulty, the car senses the clutch being engaged and hence switches off the cruise control.
    Same way when you have a working cruise control and depress the clutch, the cruise control swicthes off.
  4. Re: 2007 A4 cruise control stopped working
    Aug 2011
    Aldershot
    6 Post(s)
    I'd guess clutch switch as well, here is my guide on identifying and replacing your clutch switch, nice easy job an quite cheap to do yourself with minimal skills.
    https://www.vwaudiforum.co.uk/forum/s...-Clutch-Switch
    3 2 0
  5. Re: 2007 A4 cruise control stopped working
    Aug 2011
    Aldershot
    6 Post(s)
    seems this was a common fault around 56 - 57 plate UK A4's, guess Audi did not see it as a life threatening issue so did not recall?
    Nov 2008
    Try the clutch pedal switch, most likely that will be the problem. My cruise wasn't working either, I just changed the clutch pedal switch today, only took me 5 minutes and voila, it works perfect now. The switch only cost me £14 from my local Audi dealer.
  7. Re: 2007 A4 cruise control stopped working
    Apr 2012
    Slough
    Thanks bud solved all my issues :-))
  1. Passat B5.5 2005 Cruise Control Stopped working...help!
    By bk.bas99 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-08-2012, 01:18 PM
  2. Cruise Control stopped working
    By needhelp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 21-01-2011, 10:32 PM
  3. Cruise Control stopped working - Crasher??
    By moreski in forum Bora - 1998 - 2005
    Last Post: 14-08-2010, 01:49 PM
  4. Attention Cruise control stopped working
    By DeepPurple in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-11-2008, 01:19 PM
  5. Cruise Control stopped working
    By hoops1961 in forum Audi A4 - Archive Topics
    Last Post: 14-04-2007, 06:38 PM
