Thread: 2.0 16v (ABF) 1800 RPM - 2200 RPM Slight Misfire
Results 1 to 1 of 1
  1. 2.0 16v (ABF) 1800 RPM - 2200 RPM Slight Misfire
    Dec 2008
    Kent UK
    Hi Guys, please help with an issue with my 1996 2.0 16v(ABF) 130k Miles
    At 1800rpm - 2200rpm there seems to be a misfire at all times, in all gears and at idle.
    Parked in neutral holding it at 2000rpm it is very pronounced so its not just me thinking the car feels a bit woolie whilst traveling. Its not a big BANG misfire it just misses a beat.
    It doesnt seem to be losing much power but its not GTI standard at the mo. If you change gear at this rev range it seems to rev up say 100 - 200rpm as you push the clutch (Almost like I cant drive properly but it only does it around this rev range.) Iv adjusted the throttle cable linkage, and cleaned switch/elecs and inside throttle body.
    I have fully serviced it with Bosch or O.E parts including plugs, leads, cap, arm, filters etc I have replaced all the vacuum lines and fuel pressure regulator. Used redex.
    This is my 1st 16v after a 90 mk2 8v and a 97 mk3 8v (agg) and have looked at the usual golf tricks. Relays look new (changed before) but i will get the 2 usual culprits when I go past a vw dealers. Apart from a decat and full stainless system, everything is how Zee Germans intended it to be.
    Thanks for anyone who can help or has suffered simular problems.
    Chris
  1. Hesitation/jerking 1800-2K rpm
    By Canetoad in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-05-2025, 04:04 PM
  2. Judder at 1800 rpm
    By Dannyg81 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-12-2009, 10:50 AM
  3. Please Help Choking tdi at 1800 - 2300 RPM.
    By arturo in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-07-2009, 12:26 PM
  4. Engine 1.9TDI (53plate) Noise / booming between 1400-2200 rpm
    By nigelr07 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-05-2008, 11:52 AM
  5. Polo engine vibration at 2200 rpm
    By Dewzbury in forum Polo - Derby - Lupo - Fox
    Last Post: 14-03-2008, 10:54 PM
