Thread: Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
  1. Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    Jul 2011
    Manchester, United Kingdom, United Kingdom
    All,
    Wonder if anyone can help shed some light on my fault with my A3 2004 2.0 (2004) tdi. I've had the car 6 months and touch wood its been issue free, now done 96k miles.
    A engine warning light appeared last week, albeit I've not suffered any power loss, mpg reduction or abnormal temperatures. I connected the diagnostic tool and it reported one fault, 17903. I've not had much success finding what the fault is other than a German blog which discussed it was :-
    It also mentioned replacing the glow plugs and fuse number 34 although I believe it was specifically for a Passatt (unsure of year)
    Any help would be greatly appreciated as I'm stuck where to go.
    Hope all had a great Xmas and new year.
    Cheers,
    Mike
  2. Re: Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    134 Post(s)
    2009 Post(s)
    What did you use to code read that and is your engine type code BKD?
  3. Re: Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    Jul 2011
    Hi Crasher,
    Thanks for the quick reply. I used a U281 OBD-2 CAN-BUS CODE SCANNER for VW/AUDI/SEAT/SKODA CAR - only just bought it when the fault appeared. It showed up 17902 only.
    I believe the engine type is BKD, it's a 2.0 tdi 140BHP and the cars on an '04' plate.
  4. Re: Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    134 Post(s)
    2009 Post(s)
    I can't see 17902 or 17903 on my listing I have here at home.
  5. Re: Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    Jul 2011
    Sorry typo, the fault code is just 17903. Given the code is not appearing on your listing is this something to be worried about?
    Anyone think a phone call to Audi dealership would help?
  6. Re: Fault code 17903 - Switch-Over Valve for EGR Cooler (N345): Open or Short to Ground
    134 Post(s)
    2009 Post(s)
    I can't find it, my GFF Light is refusing to work.
  1. EGR Fault Code....
    By djl78 in forum Golf MK3 - 1993 - 1999
    Last Post: 19-03-2017, 12:57 PM
  2. Advice needed on EGR fault code.
    By mickk in forum VCDS - General Questions
    Last Post: 19-08-2010, 12:35 PM
  3. Ground Earth Short
    By v12bug in forum VCDS - Help Requests
    Last Post: 08-08-2010, 04:39 PM
  4. Please Help 00518 - Throttle Position Sensor (G69) 31-10 - Open or Short to Ground - Inter
    By Housemaster300 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-07-2010, 12:05 PM
  5. Audi A6 1.9 tdi '04, EGR valve fault code.
    By mike audi a6 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 18-12-2006, 02:10 AM
