Thread: ESP & Glow Plug Light is on. (Panic!)
  1. ESP & Glow Plug Light is on. (Panic!)
    Dec 2011
    Morpeth
    Hi.
    Please can you give some advice?
    3.0 diesel has just started putting the glow plug light on together with traction control light and the screen says ESP fault, consult owners manual. When these lights are on, the engine seems to be in a limp mode as very sluggish and slow to rev.
    Having had a brief search, there seems to be mention of a control unit failure, costing roughy £1500 to replace. Can this be true form a 5 year old Audi with 65k miles on it?
    I haven't got any fault codes yet to help with more precise diagnosis. Is this the start of potential financial doom just after Christmas?
    Thanks for reading this far and any advice you may be able to share.
  2. Re: ESP & Glow Plug Light is on. (Panic!)
    Southern County Softy
    20 Post(s)
    It could something simple.
    Check your brake lights are working.
    Look in the vagcom section to see if there is a member in your area who can scan the car for faults.
    A4 2.5 tdi QS (mapped)
  3. Re: ESP & Glow Plug Light is on. (Panic!)
    Dec 2011
    Morpeth
    Strange one.
    Started the car this morning and no fault lights. Brake lights work too.
    Seems to have fixed itself.
    46 Post(s)
    Is any of your carpet wet in the car?
    You would really need a scan to see whats going on
    VCDS Threads
    User Locations
    Help Requests
  5. Re: ESP & Glow Plug Light is on. (Panic!)
    Dec 2011
    Morpeth
    I must panic too quickly! Took the car into local garage, only 2 fault codes appeared, glow plug on pot 4 had a mishap at some point and throttle pedal out of "sync", or words to that effect. Never missed a beat since.
  1. Important My Audi a4 1.9tdi problem ESP light and glow plug system warning light
    By Ock00 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2011, 01:33 AM
  2. Question Lost power and ESP & glow plug warning lights
    By haytch75 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2011, 01:32 PM
  3. A4 1.9tdi 130 - ESP light and flashing glow plug light
    By CrispyL in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-01-2011, 11:59 AM
  4. How To ABS + ESP + glow plug light flashing
    By Camb-Tech in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 22-01-2010, 05:56 PM
  5. ESP & Glow Plug light flashing & no power
    By A4philb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-05-2009, 03:42 PM
